Results 1 to 8 of 8
    Big Ol' mud flaps
    Jan 2012
    SLC, UT
    I found a nice piece of rubber in the dumpster at work 3'X 4'X 1/2"
    and thought "this would make a great mud flap"
    I used the stock flaps as a template. I made the new ones 3" wider to cover the outer edge of the tire, and 12" longer. The new ones are about 2" off the pavement now!!!
    I found out cutting this material is a pain. A reciprocating saw, and a jig saw dont really work. I also lubed the blade with soapy water and that didnt help.
    The final tool that got the job done was a utility knife with a new blade and some elbow grease.
    Re: Big Ol' mud flaps
    Jan 2012
    SLC, UT
    I used the stock mounts 2 screws uprgaded them to stainless.
    Feb 2007
    NW Washington
    Yes... cut with a razor blade knife.
    I think linoleum knife can also cut through rubber. anyway, thanks for sharing this DIY tip
    Apr 2015
    UK
    I just use a slitting disc in an angle grinder. Or aviation snips.
    Feb 2009
    Baton Rouge area
    Now those are some mud flaps! Thanks for sharing Lug.
    Jan 2012
    SLC, UT
    No problem
    Nov 2012
    Victoria, BC
    I'll second the use of a cutoff blade in an angle grinder. It's messy as hell, but it gets the job done in a hurry.
