Thread: Chain tensioner
Results 1 to 10 of 15
    Chain tensioner
    Jan 2012
    SLC, UT
    In case you dont already know, I like to do things as inexpensively as possible.
    So I decided it was time to put on a chain tensioner. My old method of tighten the chain sucked!
    I went to the local freight damage store and picked u some hard rubbber wheels (2) with real bearings in them.
    Then picked some bolts that fit bearing (metric)
    Bought a clamp for the torsion spring and went to work.
    Cost:
    Wheels: 5.00
    Bolts: 2.50
    clamp: .99
    Total: 8.49
    Re: Chain tensioner
    Jan 2012
    SLC, UT
    Some pics
    Re: Chain tensioner
    Jan 2012
    SLC, UT
    Getting started on mounting the wheel
    Re: Chain tensioner
    Jan 2012
    SLC, UT
    MOAR
    Re: Chain tensioner
    Jan 2012
    SLC, UT
    A few more
    Re: Chain tensioner
    Jan 2012
    SLC, UT
    Now I have to find a suitable place to mount this piece of sh1t.
    This looked good
    Re: Chain tensioner
    Jan 2012
    SLC, UT
    If you look closely at the bottom you can see the spring in there.
    Re: Chain tensioner
    Jan 2012
    SLC, UT
    Here's a close up of the spring.
    Re: Chain tensioner
    Jan 2012
    SLC, UT
    All done, painted, finished
    Re: Chain tensioner
    Jan 2012
    SLC, UT
    Well, now I just need to lube up the chain. Install the resistor for the TRE mod and go tear it up!
  1. FZ 600 Buggy chain tensioner
    By bullrider700 in forum Driveline
    Last Post: 09-09-2012, 10:52 PM
  2. gsxr why me, bad chain tensioner
    By millfab313 in forum Motor - Engine
    Last Post: 06-30-2009, 09:47 PM
  3. The Chain
    By Gotted in forum Driveline
    Last Post: 05-08-2009, 10:40 PM
  4. What are you using for a chain tensioner?
    By bngcustoms in forum Driveline
    Last Post: 12-08-2008, 06:50 PM
  5. Chain Tensioner, Up or Down, Push or Pull?.
    By DesertDrifter in forum Driveline
    Last Post: 05-14-2008, 10:36 AM
