Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 23
    Stock fuel pump to aftermarket tank
    So I have a 1999 gsxr 750 powered buggy. I made a fuel tank for it, but am staring to see some cracks form on a welded seam.
    I want to replace the metal tank with a larger volume poly tank, or aluminum. I dont want to spent a ton of money on the aluminum tank.
    The fuel sending unit is oval, and all the tanks I have seen with a sending unit mount built in are for the round style.
    How can I make the poly tank work with this sending unit? The unit bolts to the flange. Plastic would not work for this. I would need some type of backing plate to bolt through on the inside of the tank.
    Here's a couple pics of what Im looking at.
    Any suggestions would be greatly appreciated.
    Re: Stock fuel pump to aftermarket tank
    Or, do I get a different fuel pump altogether if so what am I looking for as far as psi and all that.
    Can I remove the pump from the unit and use that somehow?
    Anyone ever do this?
    Would the newer style round pump work on your engine? More than likely you would have to lower the PSI but there would be more options for a tank. Just an idea.......
    It should, thats always a option. I would even consider a different pump. I do like the plug -n- play of the stock unit. I do have a soldering iron and shrink tubing. I can modify I guess.
    This unit is F.I. so the psi should be ok, I would think.
    I use this fuel pump. It's harder to do this way. See I removed my fuel regulator and installed a aftermarket one off eBay. But when you do this.... You need a return line for the fuel to let off the pressure. See I can jump it to 65+ psi. I only need 40 to 42 psi for my honda blackbird 1100.
    Sorry for muttilpe post but iPhones suck.
    So here is the end of the fuel rail that used to have the regulator in it. But is now a flow through and the hose that comes off of it... Now has the regulator and return line.
    So here is what the regulator is.
    Look at this on eBay:
    ADJUSTABLE RED FUEL PRESSURE REGULATOR 0-140 PSI GAUGE+HOSE KIT
    http://bit.ly/Jy9Kxt
    And here is my tank. 5 gallon custom aluminum tank. Tip over vent block. One feed and one return line.
    I need to look into that, I have a fuel return already. Hmmm I wonder???
    The original tank has a vent, and a return line, along with the supply line. It has all that, things may have just got a little easier. I like easy
    So what fuel pumps do other people run in a F.I. gsxr mines a 750 any suggestions???
    Senior Member NoClue's Avatar
    Aug 2008
    Fullerton, CA
    Check the engine specs as to what psi it needs. You'll need a pump that can at lease make that psi minimum. Then you can use a regulator to bring it down.
    We'll here is what you need. Now this one is expensive. But look at the line in and out. See how it's a barb fitting on both sides.... We'll this will allow you to hose clamp the lines on. You could search google for pumps with the same fittings. Then search for a cheaper pump.
    Universal External Inline 255 LPH Fuel Pump - TRE - TREperformance.com
    Since the gallons per hour say it's high flow. We'll that doesn't really make a major difference with bike motors. See this would apply of your engine would suck down fuel at a huge rate. Hence you wouldn't run dry or lean. But with the small (compared to a v8 double pumper motor with a blower)
    Would not have a issue setting up the regulator to 45 psi with most all inline fuel pumps.
    Just google inline fuel pump. And make sure it's a fuel injected pump.
    See they make inline pumps that need to flow 8 psi to carburetors (gravity feed basically )
    And then the other end is fuel injected that needs more ( does that make sence?!?!?)
    I will post more links in a few minutes.
  1. Formula Desert Lites
    Last Post: 07-22-2013, 10:22 PM
  2. Replies: 5
    Last Post: 05-22-2012, 12:27 PM
  3. Doubledown and hair pulling fuel pressure puzzles
    Last Post: 03-29-2012, 03:46 PM
  4. Stock fuel pump question, what do these go to?
    By andy777bmx in forum Motor - Engine
    Last Post: 03-12-2009, 08:33 PM
  5. General Rules and Information for our Database
