Here is a few links to others.
Airtex E8248 in Line Electric Fuel Pump for High Flow High Pressure | eBay
Another.
In Line High Pressure Fuel Injection Pump 250BHP Universal | eBay
This one has to be the one I have in my car now. Works great
New Inline External Mount Fuel Pump | eBay
Results 11 to 20 of 23
- Join Date
- Sep 2009
- Location
- 220 miles east of Glamis>>>Aka North Phoenix Az
- Posts
- 3,653
01-05-2014 11:48 AM
01-05-2014 08:21 PM
ok, got it.
Thanks
01-10-2014 06:21 PM
I have a solution to my delimma.
My solution involves a 5 gal portable air tank from harbor freight, a weld in bung with a vented cap, some flat stock steel, the original fuel sending unit, and the original fuel sending unit mount from the gas tank.
Prices:
Weld in bung: 28.00
Air tank: 27.77
Flat stock: FREE
Stock pump: FREE
Pump mount: FREE
01-10-2014 06:23 PM
Just need to remove the yellow paint, cut off the handles and feet.
Next, drill out the hole for the filler neck, build a "sump" for the pump, cut out the bottom of the tank for the sump and pump.
Add my fuel return line to the bung already welded in the top of the tank.
Weld on all the new pieces.
Then paint it silver.
01-10-2014 06:26 PM
They also have a 11 gallon tank, but it was a little too long for the space I have.
If I had the space for it I would have gone with the 11 gal.
The 11 gallon was 35.99
01-10-2014 07:09 PM
My current tank is only about 4.25 gallons, and I can ride for a LOOOOONG time on 4.25 gallons.
Will keep you posted on the progress!
01-11-2014 10:08 AM
That tank is quite heavy. I always thought a helium tank they sell at Costco would work well. Thinner wall but plenty strong. They are larger diameter though.
01-11-2014 10:32 AM
i dont think it weighs more than 10 lbs. Plus im running 130 horses in a 650# buggy so I doubt I will notice the weight difference of a couple pounds. Especially with 13T front and 70T rear sprocket gearing is low!
Formula Desert Lites
By pride_in_motion in forum Class DevelopmentReplies: 53Last Post: 07-22-2013, 10:22 PM -
Anyone using a fuel pump to pull fuel from top of fuel cell and use busa stock relay?
By twvette in forum Motor - EngineReplies: 5Last Post: 05-22-2012, 12:27 PM -
Doubledown and hair pulling fuel pressure puzzles
By amergin in forum MiniBuggy.net Lounge!Replies: 17Last Post: 03-29-2012, 03:46 PM -
Stock fuel pump question, what do these go to?
By andy777bmx in forum Motor - EngineReplies: 3Last Post: 03-12-2009, 08:33 PM -
General Rules and Information for our Database
By K-fab in forum Class DevelopmentReplies: 12Last Post: 09-19-2007, 08:27 PM
