I used SS bolts w locknuts on everything that didn't need gr8. Have to use antisieze on SS. But locktight blue on everything here, unless locknut.
Thread: What to loctite?
Results 11 to 15 of 15
- Join Date
- Dec 2006
- Location
- NW Georgia
- Posts
- 2,572
07-29-2013 07:49 AM
- Join Date
- Feb 2007
- Location
- Gilbert, AZ
- Posts
- 799
07-31-2013 10:04 AM
Skip the loctite and go with lock wire. Bit of drilling involved, or use socket head cap screws that are pre-drilled.
- Join Date
- Sep 2011
- Location
- Chattanooga, TN
- Posts
- 389
07-31-2013 11:59 AM
Everything is blue loctited on my buggy other than the brakes and rear hub mounting bolts. They are red loctited (need heat to break free. If you coat the threads on stainless, the loctite can prevent galling and dissimilar metal corrosion too. I do use nickel antiseize on rotors, hubs, wheels to hubs and other faces.
- Join Date
- Jul 2013
- Posts
- 39
08-04-2013 10:03 PM
Thanks gentlemen, I've been using blue on everything so far.
