Thread: welding tips
Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 22
    welding tips
    i think some "welding tips" will be an excellent thread to start on here! maybe someone already done this, and i just couldn't find it. looking through many builds on this site, i've seen everything from absolutely beautiful welds....to "bird crap" welds. to start this, i'll let everyone know that i am a "self taught" welder(so, i'm not saying my welds are the greatest welds i've seen)! now, my job is a welder/fabricator with a trucking company. so here are a few mig welding tips i'll start with.....#1: get the welder set(many welders have good starting points listed for the thickness of metal you will be using). if you don't have a chart to start with, use some scrap metal and experiment with different heat settings and adjust your wire feed to find what works the best. after a while, you'll be able to adjust by the "buzzing" sound you hear. many things can affect what settings work best for different people(one example: how close you have the nozzle to your work piece) #2: i like to watch the "puddle" as i move along. it is easy to "undercut" your weld if you aren't paying attention to the "puddle". an "undercut" area WILL be a weak spot, so try to avoid doing this.
    Re: welding tips
    Dusty, i agree, great topic. I started a similar titled titled " https://www.minibuggy.net/forum/proje...ild-buggy.html ". Also the rorty website has some great pictures of problem welds. My advice..... if you think welding is like gluing pieces together, its probably being done wrong
    Re: welding tips
    Jul 2009
    Fort Worth Texas
    Yeah,
    I got a tip.
    DON'T BUY A FLUX CORE ONLY WELDER.
    Truth is its not bad, but welding splattering clean up is worth 50 or 100 more bucks NOT to have to do it.
    I was on tight budget when I bought welder brand new from Tractor Supply. Hobart is good enough for me, but if I had it to do over, I'd of purchased a welder that uses shielding gas. I know as well as any, you gotta do what you gotta do.
    my .02
    Glock n Ballz
    Ft. Worth, Tx
    Re: welding tips
    yeah, i agree! many of the inexpensive welders come set up with flux core wire, but some can be converted to gas. if i remember correctly on my hobart 130, i just needed to switch the polarity, get the bottle of gas, and a spool of wire. it was set up for flux core(and came with a very small spool of flux core wire), but it came with the hose and regulator to use with gas. and i lucked into a FREE argon/co2 mix bottle!!!
    Re: welding tips
    Re: welding tips
    i've only had a chance to go through a little bit of this link so far.....and i've already learned quite a bit!!!! thanks for posting this!
    Re: welding tips
    Oct 2009
    Tonka I checked out the sight ya posted. Thanx alot . I think there's about two boat loads of info with the links you provided. lot's of good info for all types of welding. Two thumb's up
    Re: welding tips
    I personally see no reason to spot or pulse weld anything other than sheet metal, you are better off with a consistent flow. You can achieve a perfectly decent looking, and faster mig weld without it.....
    A few I did last week on a chassis, and i'm not what i'd consider a pro even though I do a lot of welding daily....
    www.SinisterSandSports.com
    918-521-3736
    Re: welding tips
    yoshi, i agree! the only time i've used pulse welding, is too reduce warpage when replacing body panels. in reality, everything could be tig welded.....but it is a much slower process! one of the big advantages of mig welding....is the fact that it is fast! and even though i weld for a living(tig, mig, and arc). i also do not consider myself a pro, as i am "self taught"
    however, "there is more than one way to skin a cat"! So, i'm not saying the way i do ANYTHING, is the best way, or even the right way! i just thought this would be a good subject (that many people would have ideas, and advise) to help those who don't feel comfortable with their welding skills???
    Re: welding tips
    Thanks for sharing that link! Roaming through the website I stumbled upon Lincoln welding motorsports school in Cleveland, Ohio! Its solely for motorsports application and only a couple weeks long...I'm definitely going to attend it
  1. Welding on automobile cv cups
    By urubu in forum Driveline
    Last Post: 01-04-2009, 02:05 PM
  2. Bronze welding
    By LEE1969GB in forum Frame
    Last Post: 04-20-2007, 04:23 PM
  3. Tig welding help.
    By Mike in forum MiniBuggy.net Lounge!
    Last Post: 12-03-2006, 03:57 PM
  4. Welding table & Chop saw table
    By Mike D in forum Shop Talk
    Last Post: 08-14-2006, 07:10 PM
  5. Scooters first welding test
    By Diverbill45 in forum MiniBuggy.net Lounge!
    Last Post: 12-27-2005, 09:44 PM
