Results 1 to 5 of 5
    Fit 5 point harness
    Jan 2007
    United Kingdom
    Can anyone tell me or show pictures of how to fit a five point harness with the standard pilot seat still in use, The 4 origonal mounts are not a problem its the crutch strap I am not sure about, do I need to cut a hole in the seat or put a tube under the seat to mount the strap to and how far back.
    Thanks Lee.
    Re: Fit 5 point harness
    Jan 2007
    Baja California Sur, Mexico
    I have a tube right under the front part of my seat with a tab with a 3/8" hole that bolts the crotch strap to, sorry no pic.
    Use the seat frame...It is easy to put a bolt through the pan in the bottom of the seat frame....I don't have a picture, but just performed the same job on my daughters pilot...Easy to do, you just have to take the seat out of the frame to do it.....
    Hoodlum
    Jan 2007
    if I get a chance I will take a pic tomorrow.
    Feb 2008
    Maryville, Tennessee
    There are two sleeves protruding through the frame used to attach the steering column support. *This is an ideal location to mount a bracket for the fifth point and is very strong. *The sleeves will need to be tapped and a simple "L" bracket fabricated to accept the connection point.
