Page 2 of 2 FirstFirst 1 2
Results 11 to 13 of 13
    Re: FL250, FL350, and FL400 gear ratios?
    Sep 2014
    West Palm Beach FL
    Blog Entries
    2
    Is this where I should say I meant the pilot was 9.8? Lol
    Sep 2017
    Utica, Nebraska
    Quote Originally Posted by LIDUNO View Post
    Lol up to you. I've triple checked the FL250 manual and it doesn't list ratios for the Salisbury CVT or the gear reduction box. If I had to take a wild guess, they have to be close to the FL350 maybe a bit deeper gearing in the gearbox. So 9.8:1 maybe 10:1 or there abouts. All it stated was the brand of CVT and that was it. Then some changes made from the roll bar to roll cage, lights.
    Ended up finding the stuff for the FL350. It's on page 1-4 in general information in the service manual. Has the Salisbury CVT ratios listed as well as the final ratios.
    Forward is 2.92:1-0.63:1
    Reverse is 2.92:1-2.04:1
    Final reduction ratio Forward 9.99:1
    Final reduction ratio reverse 8.79:1
    The first two are the CVT clutch ratio range.
    I see you found the Pilot’s internal ratio already. Was going to say about 10:1
  1. CVT gear ratios
    By abhay in forum Show off your toys in here!
    Last Post: 10-24-2011, 04:05 PM
  2. 03 gsxr600 gear ratios
    By voodoochikin04 in forum Motor - Engine
    Last Post: 05-25-2010, 08:32 PM
  3. Ratios of various gear boxes
    By LiveWire in forum Driveline
    Last Post: 10-04-2007, 09:30 AM
  4. How to calculate gear ratios
    By bajaBrothers in forum Driveline
    Last Post: 03-06-2007, 09:41 PM
  5. Yamaha R-1 gear ratios
    By redbeard in forum Driveline
    Last Post: 10-11-2006, 10:12 AM
