Results 1 to 4 of 4
    New to the FL250, have question
    SO I finally have an FL250. It is a 1982 from what I am told. but I have some questions.
    1. clutch adjustment, is it supposed to free roll when the engine is not running. it does not free roll with engine off. it is very diffuclt to push around.
    2. hubs, are there hubs I can use to convert to 4x110. I am reading conflicting information about using Honda 250r/400ex components.
    I am sure I will come up with more, but I picked it up last night. and this afternoon I am going to let my son rally it around and see what else comes up.
    Re: New to the FL250, have question
    Jan 2014
    5 Min from the dunes!
    I fully restored and built a custom caged 250 last year as a school project. Most rear quad hubs have the same spline like honda yamaha etc for the fl250 axle and same thread diameter for the big lock nut. I put yamaha banshee hubs on mine with a few washers on the back side of the hub and it worked fine. As for your clutch spacing it will be a little hard to push around but the belt should be still sliding on the primary clutch attached to the motor shaft when its pushed. When you pull start it have someone sit in it just in case the clutching is incorrect so they can hit the brake. Not the best way to do it but hey it works. Post pictures
    -Fl350 resto mod-
    -Wind turbine electrician-
    Feb 2009
    Baton Rouge area
    I'm sorry hans... i just don't believe you. If you were to post pictures... then I would believe you.
    seriously, I can't help much. Just wanted to pics of the fl. Cool little rides, imo.
    ill upload some pics to photobucket so I can share them
  1. 1984 fl250 reduction box modification question
    By T_Rob90 in forum Honda's Pilot & Odyssey
    Last Post: 12-13-2012, 01:36 PM
  2. Fl250 with arctic cat 500cc question
    By Scottbrock in forum Honda's Pilot & Odyssey
    Last Post: 10-21-2012, 03:27 PM
  3. FL250 front/rear hub question?
    By outtakontroll in forum Honda's Pilot & Odyssey
    Last Post: 05-13-2011, 04:38 PM
  4. 78 fl250 front shock question?
    Last Post: 10-14-2009, 02:13 AM
