Results 1 to 6 of 6
    Water cooled head and radiator
    Question? what is a good radiator to use on when you install a water cooled head. Just find one that fits below the air box, or behind the driver seat. Also do those kits come with a water pump, or how does the whole thing work? thanks
    Re: Water cooled head and radiator
    Feb 2006
    Winder Georgia
    Aftershock Motorsports they have an entire kit rad and head.. Kit
    does this use some sort of water pump, iam in the dark here it says nothing about a pump
    It uses thermosypohn. The hot water rises out of the head and into the radiator. As the water cools, it flows down into the head. It self regulates in that the hotter the water gets, the faster it will flow.
    thanks that explains it
    I have a couple of radiators from a 80's CR250 if you need them for cheap.
  1. CBR600 radiator question
    By andy777bmx in forum Cooling
    Last Post: 03-17-2010, 04:48 PM
  2. Installing water cooled head on FL350
    By greasemnky in forum Honda's Pilot & Odyssey
    Last Post: 06-09-2008, 04:38 PM
