Thread: Fl350 tuning
Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 27
    Fl350 tuning
    Hello all.
    I have a fl350 that I cant get to idle, I can set the idle screw all the way in, and it still dies. Only way I can keep running is by giving it a little throttle. I've cleaned carbs. Please help.
    Re: Fl350 tuning
    Petoskey, Michigan
    Welcome to the site.
    You have a two stroke and these need a regular test or you can just run it and gamble
    You need to do a crank case pressure test. If the seals are leaking in the crank it will never idle very good and its the start of it wearing out the bottom end and you could melt the piston down if you have a seal leaking and it gets bad enough. Also gaskets and vacum hoses should be checked or replaced if any dryrot on hose to fuel pump.
    Also of note the screw should not be all the way in. It should be out 1-1/4 to 2 turns and then adjusted in or out a little.
    Do not crank it in to tight or you can cause irrepairable damage.
    Re: Fl350 tuning
    It's not that it won't idle very good, it won't idle at all. Reeds look good, no air leak in boot, fuel filter is good. I'm stumped.
    Re: Fl350 tuning
    Sep 2014
    West Palm Beach FL
    I'm gonna ask the obvious questions, forgive me if they're too obvious.
    Did you try turning the idle screw all the way in or are you talking about the A/F screw?
    Have you tried a new plug?
    Ever done a compression test?
    Re: Fl350 tuning
    Petoskey, Michigan
    Quote Originally Posted by Buggy guy View Post
    If you think the rubber boot around the carb is the only place air can leak you either need to start learning a lot or paying a good shop to fix it.
    Not being rude just truthful.
    Re: Fl350 tuning
    A/For is 1 1/2 turns out, idle screw is all the way in. I do know about air leaks, did a test with staying fluid. I've had air leak issues with sleds, and I could still get them to idle.
    Re: Fl350 tuning
    Did it idle before you cleaned the carbs? Or ever?
    I'm not familiar with the 350 carb, is the idle screw built into the choke knob like on a bike? If it is, your probably way out of the range of the idle.
    Re: Fl350 tuning
    The machine was in pieces, got it back together and running, but never able to get it to idle. I have carb off again, going to check jets. Idle screw is separate. It just hold plunger up. Have I feeling my jets are wrong.
    Re: Fl350 tuning
    Petoskey, Michigan
    You NEED to do a crankcase pressure check.....
    Its a two stroke.
    Re: Fl350 tuning
    K, explain how.
  1. FL350 Odyssey vs. Joyner 650 Sand Spider
    By Yondering in forum Turnkey buggies and sand rails
    Last Post: 10-06-2010, 08:45 AM
  2. FL350 paint color #'s?
    By outtakontroll in forum Honda's Pilot & Odyssey
    Last Post: 02-14-2010, 02:16 AM
  3. fl350 class in baja 500???
    By fl250driver in forum Honda's Pilot & Odyssey
    Last Post: 08-30-2008, 08:23 AM
  5. Wizard / Donahoe Racing Suspenion Tuning Seminar
    By KingGlamis in forum Suspension - Wheels & Tires
    Last Post: 09-20-2006, 09:16 PM
