The following parts from other machines will fit the FL250:
*ATC110 CDI are the same part number and cheaper Honda # 30410-958-003/8
*1973 - 74 Honda CR250 head will bolt on to a Honda Odyssey FL250 engine
*Yamaha Warrior 350 Rear Hubs and Wheels – Direct bolt on, same splines use a couple of 1" washers for spacers
*Early 86-87 TRX250R/Fourtrax front hubs have the same bearings inside and out
*1975-1983 Goldwing 1000 Fuel Petcock is the same as the FL250
* Reduction Gear Chain #50 with master link.
Thread: Odyssey Parts Exchange
Results 1 to 5 of 5
02-02-2016 09:12 AM
02-03-2016 07:57 PM
That's good info. Thanks for posting it.
- Join Date
- Oct 2010
- Location
- Oregon
- Posts
- 85
02-03-2016 11:01 PM
How about a pull start?
Mini buggy construction
FL350 rustbucket Rotax 503 conversion
Custom buggy on hold.
02-05-2016 06:10 AM
Haven't found a replacement for the pull start. But I am working an idea using a Honda pull recoil starter. I am looking for a engine block with a crank in it to start on the design. Hopefully it can be made for between $25 to $75.
02-12-2016 02:07 PM
This petcock kit, GL1000 / GL1100 Petcock Repair Kit (included in GL1000 and GL1100 Mast | Randakk's Cycle Shakk® will fit the Odyssey FL250.
FL250 Parts Exchange
By Mississippian in forum Honda's Pilot & OdysseyReplies: 2Last Post: 01-15-2016, 08:17 AM -
Odyssey parts 85 350 FNR box and rear suspension
By LIDUNO in forum For SaleReplies: 9Last Post: 12-11-2014, 03:31 PM -
Honda Pilot and Odyssey Parts
By 1frc in forum Honda's Pilot & OdysseyReplies: 21Last Post: 12-07-2012, 09:21 AM -
Odyssey and Pilot Parts
By 1frc in forum For SaleReplies: 0Last Post: 01-19-2012, 05:10 PM -
fl250 odyssey parts
By trenton ohio in forum For SaleReplies: 5Last Post: 10-01-2010, 03:56 PM
