Thread: Bent Front Beam
Page 2 of 2 FirstFirst 1 2
Results 11 to 19 of 19
    Re: Bent Front Beam
    Did you figure what ATV hubs and rims are on the front. That is a great upgrade for the frontend. Yamaha Warrior 350 rear hubs and rims will fit the stock Ody rear axle, I already have them.
    Re: Bent Front Beam
    Dec 2015
    Near Pittsburgh, PA
    The bolt pattern is 4x110.
    I am betting it is all Honda Fourtrax stuff...I believe that's what I read that some where using.
    Couple pics I snapped this morning when I got home:
    Let me know if this is something you're interested in and I can pull the hubs off for a better look.
    We are supposed to get a storm here so I may need to hold off a couple days. It's in the garage right now but only because my wife is at work.
    Re: Bent Front Beam
    Looks like Honda to me.
    I tried to upload a drawing of my rear suspension design. I have tried to upload photos before and they fail.
    Re: Bent Front Beam
    Dec 2015
    Near Pittsburgh, PA
    I hacked the front end off the frame so if you want to send me your info I can see how much it would cost to ship these.
    Do you just want the hubs, spindles and j-arms?
    Re: Bent Front Beam
    Dec 2015
    Near Pittsburgh, PA
    I was originally building the entire frame, but instead of scrapping this one, I may as well just graft my front and rear ends that I will build to it...so i guess it will technically still be an Odyssey.
    I will build a lower cage section from square sort of like the Piranha then use the the bent part of the cage to top it since I don't have a bender....may as well recycle!
    Re: Bent Front Beam
    That is a sharp frontend setup. Should give you lots of travel.
    I found hubs and aluminum rims for the front locally for $60.
    I have the rims aluminum rims cleaned for the rear and the new tires came in.
    Now if I can get my rear suspension design off the drawing board.
    I still can't get pictures to upload.
    Re: Bent Front Beam
    Dec 2015
    Near Pittsburgh, PA
    Sounds good.
    I was just going to give you this stuff for cost of shipping so if you do want anything let me know...otherwise I will Ebay it.
    Re: Bent Front Beam
    Good deal. How about the J-Arms without the hubs to 39705. FedEx is usually the best.
    Re: Bent Front Beam
    Dec 2015
    Near Pittsburgh, PA
    Give me some to check it out.
  1. Front modular clips
    By ProtoDie in forum ProtoDie Buggy Group
    Last Post: 06-24-2015, 05:12 PM
  2. front engine chassis
    By tedsfab in forum MiniBuggy.net Lounge!
    Last Post: 06-23-2014, 11:31 PM
  3. Front Wheel kits - front brake lines
    Last Post: 04-24-2014, 09:32 AM
  4. New Front End, longer wheel base & Video of testing.
    Last Post: 08-16-2009, 08:37 PM
  5. Front Wheel Alignment For Off Road Kart
    By BigD in forum Suspension - Wheels & Tires
    Last Post: 03-22-2006, 09:21 PM
