Thread: Kuma's EBK
Page 4 of 5 FirstFirst ... 2 3 4 5 LastLast
Results 31 to 40 of 50
    Re: Kuma's EBK
    #31
    Congrats Kuma, cool car for sure.
    Re: Kuma's EBK
    #32
    Jan 2009
    Los Angeles
    Nice!
    Able to get any video?
    Re: Kuma's EBK
    #33
    Update on the car, I picked up an '07 busa motor with low miles, it is mounted in the car now, getting an exhaust built, I need to setup the throttle and shifter linkage, wiring and air box.
    want to have it ready for Glamis but I'm beginning to panic, I run into little problems that seem to take much longer than they should to work out.
    Anyone have experience with the bust hydraulic clutch? the one that I have was broken at some time and welded, I'm assuming this was because the master cylinder was too big and it just acted as a hydraulic jack, I think my master cylinder is a 3/4" CNC, is that too big or is there a modification used to limit the volume of fluid going to the slave?
    Re: Kuma's EBK
    #34
    You need an adjustable stop on the clutch pedal. Limit the stroke of the master cylinder and you limit the stroke of the slave cylinder.
    Re: Kuma's EBK
    #35
    I put a spacer and a jam nut under the rubber bellow to limit master cylinder travel. I used a 5/8 Mc to give the clutch slightly better feel.
    Re: Kuma's EBK
    #36
    Thanks for the tips, I consider one or combination of both of these suggestions.
    Any suggestions on shifter linkage, I'm trying to figure a way of adding an extra link in the setup that was on the car for the 750 engine, now I'm thinking on some how hybridizing adding a cable but not sure how that will hookup to the shifter, suggestions, pictures?
    Re: Kuma's EBK
    #37
    Theres also a clutch slave saver for the busa. Reccommend!!
    Re: Kuma's EBK
    #38
    If your mean the stock hydraulic clutch slave cylinder, that has the rod that actually moves the clutch, I have that.
    Re: Kuma's EBK
    Re: Kuma's EBK
    #40
    That part keeps the cylinder from breaking off if the master pushes too hard,
    I would still run a limit of sorts.
