Results 1 to 3 of 3
    Trax 2 chasis question
    I'm planning on building a Trax 2. I have the plans from edge products but have some concerns. First I might have trouble getting steel in metric sizes so I need to know what imperial sizes match up with metric. But my main concern is the chasis tube size is
    30mm x 30mm x 1.6mm wall square tube. Seems a bit small both in OD and especially the 1.6mm wall. Has anyone build one to this spec? Is it holding up?
    Re: Trax 2 chasis question
    30x30 is roughly 1.125" and the 1.6 wall is .0625". Seems pretty thin.
    Where are you, since you're looking at imperial stuff? You can convert pretty easily. Divide by 25.4 and you'll get SAE numbers.
    Mar 2015
    Yettem California
    I built one not exactly to plans, size wise it is and I used 1-1/8" .095 round tube for chassis and cage with 3/4" .095 tube diagonals, fun little kart. Gran daughter was jumping it a couple foot in the air having a blast and nothing broke
  1. Quick Question.
    By Teoz in forum Motor - Engine
    Last Post: 06-26-2012, 05:07 PM
  2. the original TRAX from edge
    By flyinwall in forum MiniBuggy.net Lounge!
    Last Post: 12-30-2011, 02:50 AM
  3. Fuel Flow Question
    By buschman in forum Motor - Engine
    Last Post: 03-12-2011, 05:43 AM
  4. 78 fl250 front shock question?
    By outtakontroll in forum Honda's Pilot & Odyssey
    Last Post: 10-14-2009, 02:13 AM
  5. Quick question about trailing arms
    By andy777bmx in forum Suspension - Wheels & Tires
    Last Post: 01-22-2009, 08:32 PM
