Results 1 to 6 of 6
    525-530-630 chains sprockets
    i have a stock 525 front sprocket on my zx10, i beleive the sprocket on the jeffco tranny is a 630. i think that i would need to stay with the larger setup(630) because of the added weight. *if anyone with knowledge on the topic or running the jeffco unit could help as i only see down conversions available 525 -> 520 thanks
    Re: 525-530-630 chains sprockets
    If you can't find a sprocket to work for you, you can always get a custom sprocket made.....I used a place called advancedprecisionproducts.com ( 1-888-347-7262). They didn't charge me an arm & leg to get the sprocket machined and heat treated. And were also fairly quick.
    Also Jeffco does make a 530 sprocket for his rearends if this would help.
    thanks for the reply ill check that company out. and ill be contacting jeffco on monday.
    Feb 2006
    Winder Georgia
    you can use a 520 drive sprocket with a 530 rear sprocket, but you have to use 530 chain, the 630 stuff is different all together, you would have to have a 630 drive sprocket then...
    i found some dimensions on sprockets and chains last night and your reply supports by decision so thanks bugpac
    Check with Hyper Racing, I think they have 630 counter sprockets down to 13t.
    Currently on a two year walkabout
