Page 2 of 2 FirstFirst 1 2
Results 11 to 16 of 16
    Re: 6 SPLINE 1-3/8 PTO SHAFT AS JACKSHAFT??
    Duck in a Tux jimmyg's Avatar
    Sep 2016
    Bendigo AUS
    Well, if Jimmy says, it will work . . .
    If, those splined shafts are hardened, which seems to be the case, then a 1 3/8 splined shaft should do the trick.
    What about sprockets or sprocket hubs?
    Duck engineering!
    1" 3/8" is a 51mm!! solid steel shaft. It should be heat treated and case hardened. It's not going to shear. Ever.
    Quote Originally Posted by ODB View Post
    The Edge Products out of AUS used them for drive shafts on their carts for awhile but switched to CV’s when the high HP engines they were using started to blow apart the female part of the PTO slide shaft…….if used as a Jack shaft without the “slide” you should be fine……Tractor Supply and other Farm Stores carry all sorts of hubs and other parts for spline shafts.
    I was wondering what EDGE used on there spools shafts etc etc. What do you mean by the slide?
    Duck engineering!
    Thank you Duck man ha ha, sounds like it will hold up fine.
    Sep 2016
    Bendigo AUS
    Thank you Mr Duckman. Lol
    Quote Originally Posted by Jeremy Gulley View Post
    The “slide” is the female part of the tractor PTO shaft that they were using for rear axles on their cars which allowed for suspension movement…….it was the “weak” link in the whole system……the plans had you milling steel plate rings that were welded on the outside of the shaft to help keep it from exploding…..
    Awww okay got yua.
  1. Cv Drive flange spline count and shaft diameter?
    By ramitharder in forum Driveline
    Last Post: 12-23-2010, 01:33 PM
  2. Custom Center-drive: Keyed vs. Spline Shaft
    By DMoneyAllstar in forum Driveline
    Last Post: 04-29-2010, 06:41 PM
  3. Motorcycle engine drive shaft spline???
    By razorback in forum Driveline
    Last Post: 12-27-2009, 12:54 AM
  4. SkiDoo jack shaft spline
    By Montanaminirail in forum Driveline
    Last Post: 11-27-2008, 12:29 PM
  5. Any pics of jackshaft or double jackshaft setups?
    Last Post: 05-27-2008, 01:01 PM
