Results 1 to 3 of 3
    Driveline Questions - Building Single Seater (930s, sprocket, brakes, etc.)
    I’m currently working on a mini buggy based on the KJ Raycing crosscart chassis (single seat, maybe 750lbs). I’ve done a ton of reading here but still have a few specific questions….
    Plan to use a Ninja 650 engine (~70HP) on 23-24” tires. I think I’m going to try about 13/60 gearing to start.
    Stock chain is a 520. Ok to just stick with that size on this buggy?
    I’m working on a center section that terminates with EMPI 930 conversion flanges. I plan to use Intrepid wheel hubs and F-150 outer CV pieces. A-arm rear.
    Is there anything special I need when getting inner 930 CVs? Any generic ones (cheaper) ok?
    Plan to use the bike rear caliper and probably one of the discs. (Raptor 660 parts and brakes up front) Should I use the stock rear 9” or stock front 12” brake disc?
    Any issues using maybe Ĺ” 6061 to make adapters to mate the sprocket/disc to the 930 flanges?
    Appreciate all the great info up to this point and any insight you can share on these questions.
    Thanks!
    Re: Driveline Questions - Building Single Seater (930s, sprocket, brakes, etc.)
    May 2019
    California
    The 520 chain should be fine with your setup. I believe most guys here are using that size typically unless they have to jump to a double wide chain.
    I plan on using one for my buggy temporarily until I get my FNR built.
    I dont know about the cheaper 930 cv's but I may try it out myself as I'm getting to that point soon, but my buggy will be heavier than yours as it's for 2 people.
    I've been following KJ racing on YouTube and may eventually build a single seater but it's not in the cards for now. Good luck.
    Quote Originally Posted by XJZ33 View Post
    The 520 chain should be fine with your setup......snip.....
    Thanks for the input. I decided to go with the 520. I picked up an inexpensive 930 to play with and see what movement I can get.
  1. Rear Live Axle CV Driveline Questions
    By thenxtEMIG in forum Driveline
    Last Post: 02-02-2015, 04:11 PM
  2. What next? Building a two seater for winter...
    By Blownz28man in forum Frame
    Last Post: 03-30-2011, 02:39 PM
  3. Kawasaki 700 - Driveline questions
    By loonatik503 in forum The Welcome Mat
    Last Post: 01-26-2011, 02:35 PM
  4. Driveline help Please!!Shaft or sprocket Drive??????
    By dirtreaper in forum Driveline
    Last Post: 04-13-2010, 02:15 PM
  5. Frame building questions?
    By IronSpade in forum Frame
    Last Post: 08-13-2009, 07:03 PM
