Results 1 to 4 of 4
    How to size an unknown CVT belt for cross reference?
    I took on a project FL350 that is getting a 503 air cooled transplant. I have figured out that it came from a Polaris Escapade snowmobile (I think it was made in 1987). It has an MBL - Three Stars belt with some identifying numbers on it, but I cannot find any info on the belt, even on MBL's website. They also have not responded yet to an email.
    The numbers are in small text and repeat line after line, but one of the numbers increments each line:
    SP4440 Z4 22 091 MADE IN USA 377
    SP4440 Z4 22 092 MADE IN USA 377
    SP4440 Z4 22 093 MADE IN USA 377
    SP4440 Z4 22 094 MADE IN USA 377
    SP4440 Z4 22 095 MADE IN USA 377
    SP4440 Z4 22 096 MADE IN USA 377
    SP4440 Z4 22 097 MADE IN USA 377
    The width is about 1.25" (32mm) and the length on the outside is roughly 44 5/16" (1129mm). Does anyone know of a website where I can cross reference this, or at least tell me if the dimensions match the stock 350 belt?
    Thanks.
    Mini buggy construction
    FL350 rustbucket Rotax 503 conversion
    Custom buggy on hold.
    Re: How to size an unknown CVT belt for cross reference?
    I must have deleted all my drive belt link stuff, probably because the headaches it gave me during the 600 Pilot testing! I just searched and searched, and found a few different helpful articles and charts. What it came down to with me was taking the buggy to a big sled shop and trying a bunch of them. An online retailer with a generous return policy is an option.
    I race, therefore I am
    S.W. Michigan
    here is a site I have used over the years
    https://www.rockauto.com/en/tools/be...)+belt,1001354
    I when through this, just found as much info as I could I bought a belt on Amazon, it was too long, I was able to return it and from there I knew what I needed, next one worked fine.
    it sounds to be that that is not too far off from a stock pilot or oddy belt, you should check out the pilot oddy forum
  1. front suspension design w/o physical wheels/tires to reference?
    By shane12286 in forum Suspension - Wheels & Tires
    Last Post: 10-07-2015, 07:43 AM
  2. Formula Cross
    By bc124 in forum MiniBuggy.net Lounge!
    Last Post: 12-11-2013, 10:52 AM
  3. My Kart Cross design
    By bigblock in forum Projects in Progress
    Last Post: 08-07-2011, 03:57 PM
  4. Kart cross
    Last Post: 12-30-2008, 07:59 AM
  5. They Call it UTV Cross
    By Kstuck in forum The UTV Area
    Last Post: 08-06-2007, 01:04 PM
