Results 1 to 10 of 11
    Jackshaft or no??
    Hey y'all!! I searched and found a lot on cvts and jackshafts but no direct answer to my specific question; with enough gearing, will my clutch handle direct drive without a jackshaft? I'd rather run direct drive utilizing the bike transmission unless I'm gonna smoke a clutch in 10 minutes.
    Re: Jackshaft or no??
    Jun 2014
    Upper Peninsula, MI
    Do you have more information like what motor you're using, how much you expect the buggy to weigh with you in it, how fast you want to go, your typical riding conditions, etc. That'll give us a better idea of what you're working on. However, usually the issue with not using a jackshaft to get lower gearing is the rear sprocket has to be so large that you lose all your ground clearance.
    I have replied a couple times. I'll wait awhile and see if they post
    Ok one more time: weight is uncertain because the fabrication isn't complete yet. I weigh 230 an I'll be running a Kawasaki 900. Most of the chassis will be 1.5/.120 dom, trailing arm rear an A arm front, 28x10x15 tires, thinking around 13/51 sprockets. 70-80 would be great but a strong 65-75 would be welcome. Baja 500 is the ultimate goal but Texas off-road is the jumping off point. I don't think I'll weigh in at nearly what a kitted out 2 person side by side weighs
    Blog Entries
    1
    You will need deeper gearing than that. You will also need reverse for a Baja race. And lots of chains........
    That's one word I was hoping to avoid; reverse.....
    So a jackshaft is going to be a necessity.....now to find a gearbox that will take the HP of the 900 engine...back to the I terweb
    Blog Entries
    1
    No jack shaft. RPM. angle it back so that you can run the longest chain possible. Run the largest sprockets you can. Front and rear.
    RPM gearboxes..... looks good and beefy and has reverse. Any experience?
    Long chain with idler....I'm guessing for heat purposes? According to their little page they have several different ratios so maybe that will take care of the clearance problems presented by hill climbing sprockets
  1. Help with finding a jackshaft
    By Tinman Wingmen in forum Driveline
    Last Post: 12-17-2016, 05:12 PM
  2. Brake on jackshaft??
    By jrpitdog in forum Driveline
    Last Post: 08-17-2011, 07:57 PM
  3. Any pics of jackshaft or double jackshaft setups?
    Last Post: 05-27-2008, 01:01 PM
  4. Another jackshaft design
    By tenaja in forum Driveline
    Last Post: 12-12-2006, 04:16 PM
  5. Swingarm Jackshaft
    By boilermaker in forum Driveline
    Last Post: 09-28-2006, 05:26 AM
