Results 1 to 8 of 8
    U Joint Pivot with Suspension
    Bought a buggy. Rear u joints all busted up. Rebuilding it. Do the center cross of the u joints need to line up with the pivots of the suspension? Axles will have plunge in the center with splines.
    8E23500A-94EE-43DD-9542-55E0218112C4.jpg08C12515-6DAC-493C-9E7F-4673531E416F.jpg36D6398F-764A-4CD0-AD81-F47718733E5D.jpg
    Edge Piranha with Sled Engine, 2 Margay sprint race karts, and a couple of fun Karts
    Re: U Joint Pivot with Suspension
    Quote Originally Posted by turbomike9 View Post
    The joints don't need to be on center but it does help.
    As long as the offsets are equal on each end it won't need to plunge. But the offsets need tobe really really close. Also make sure there in correct phase, this one kicked my ass.
    Sent from my SM-G973U using Tapatalk
    That said, I personally would not waste money on axles that don't have a slip yoke.. things flex and ujoints die.
    This is the direction I’m currently looking at.
    https://www.driveshaftparts.com/inde...scription=true
    Can get 1310 series yokes with the right bore and keyway to fit my current stub shafts.
    I just noticed there is also angle front to back looking from the top down. Problem??
    Shouldn't be an issue - you're stuck thinking in perpendicular planes - XZ in this example. It just leans off that plane a bit and doesn't care one bit. It's angle, not direction of angle. Does that make sense?
    I was just thinking the max travel limit of the u joints is when the yokes crash into each other and adding that second angle may affect that.
    Measuring from the rear there is about 24 degrees downward slope from the spool shaft to the wheel shaft at ride height (rear seems real stiff so I might lower shock pressure over time) Looks like 1310 series are rated for 30 degrees
    Making progress. 1310 I joints with a slip joint.
  1. Heim joint vs Johnny Joint?
    By JagerDanger in forum Suspension - Wheels & Tires
    Last Post: 08-03-2019, 01:11 AM
  2. Driveline pivot point????
    By jrpitdog in forum Driveline
    Last Post: 01-30-2011, 11:16 PM
  3. Rear Inner Pivot Angle
    By KrunchWorkz in forum Suspension - Wheels & Tires
    Last Post: 08-14-2010, 01:05 PM
  4. Location Of Inner Tie Rod Pivot Point
    By Kawabuggy in forum Suspension - Wheels & Tires
    Last Post: 10-22-2008, 10:47 AM
  5. Trailing arm pivot angle
    By PANZER in forum Suspension - Wheels & Tires
    Last Post: 12-29-2006, 02:16 AM
