Page 7 of 8 FirstFirst ... 5 6 7 8 LastLast
Results 61 to 70 of 75
    Re: Inadequate cv axles?
    #61
    Output sprockets for the Polaris gearbox are ubiquitous on Ebay, from 11 tooth to 14 tooth. Just search for Polaris front sprocket 11 tooth (or whatever) and you'll find them.
    The Polaris gearboxes also come in two flavors. The TrailBoss, Trailblazer and Sport gearboxes are F-N-R. The 2x4 and 4x4 gearboxes are L-H-N-R (Low/High). The 2x4 gearboxes don't have the FWD shaft and are cheaper than the 4x4 gearboxes. In fact, the last gearbox I bought was a 2x4 and it was cheaper than the simpler F-N-R gearbox.
    I think the internal gear ratio is roughly 2:1 on the High gearing,but I'll need to verify.
    I haven't looked at options for the internal shaft, other than the Polaris CVT, but I would have to think that the splined shaft is somehow standard.
    #62
    Jun 2014
    Upper Peninsula, MI
    Sorry if I mislead any of you, when I meant front and rear sprockets I was referring to rear as on the axle and front as on the output of the gearbox. I am still running the secondary CVT clutch on the input of the gearbox as my engine happens to be from a snowmobile so it also has a Polaris primary CVT clutch. Sorry for any confusion.
    So you are looking to have the gearbox have a sprocket on both the input and the output? That may take some more fabrication. I'm sure it could be done, but I am not sure if a current sprocket exists that would fit in place of the secondary clutch.
    #63
    Sep 2017
    Lincoln, Nebraska
    I was thinking it was both input and output. If it is only CVT input, I guess I'll be looking for suitable engines for it. It doesn't put a hamper on it, I have been debating for a while what to use for a powerplant anyway, so at least this will get me in the right direction.
    #64
    Member 67StingrayJ's Avatar
    Jan 2019
    Las Cruces, NM
    We all know about the output on the FNR, the trouble is the Input.
    No quite,.. it's standard for Polaris but proprietary to them. It's not like you can look it up in a book, find out what the spline count, pressure angle and diameter, then find a coupling for it online anywhere. At least not that I can find.
    Quote Originally Posted by 65chedderbob View Post
    Ideally, I could swap the Polaris CVT out for my 40 series CVT but the input shaft on the FNR doesn't mesh to a 40 series. My 40 series has a 5/8" bore with a 3/16" key-way. I'd accept any reasonable means of getting that 40 Series mounted the the FNR short of paying an arm and a leg.
    HARD WORK PAY$
    #65
    Jun 2014
    Upper Peninsula, MI
    Is the shaft on the gearbox large enough in diameter to machine down the splines and add a keyway? If not, you could do something funky like machine it smaller and add a keyway then make an adapter that fits over the shaft and inside the 40 series, just an idea that may or may not work
    #66
    Senior Member Jerm's Avatar
    Dec 2013
    Ontario Canada
    Hey sorry for the late reply on this, had a busy summer away from this site. Have you found a sled engine yet? I use a 500cc phazer engine, liquid cooled. I used the bulkheads from the sled including gear reduction chaincase, it has reverse and gear reduction built in. It is literally the engine and side bulkhead castings all as one assembly, bolted to the back of my buggy, then I hooked up a chain from the final drive. It works well and very little custom work was needed on the drivetrain.
    I looked into using the polaris stuff prior to buying the phazer, it is a lot of custom work.
    #67
    Sep 2017
    Lincoln, Nebraska
    Quote Originally Posted by Jerm View Post
    Still haven't found anything yet. Granted I live in an apartment so I have limited space to store stuff. I have looked into a Phazer and its definitely an option. However most Phazers I find are circa 1980s. Once I'm in a house, I'll have more options to look for engines.
    #68
    Sep 2017
    Lincoln, Nebraska
    Hey Jerm, could you tell me some dimensions of the Phazer engine? I'd like to know the width of the engine with the driver pulley, the length out to the driven pulley and how tall the engine is. I'm wanting to draw a scale model so I can make an accurate lay out of my build on paper, so I have at least a heads up of what I'm looking at. If I go the Phazer route, do you think using a Honda Civic radiator is large enough to keep it cool? I may run a water temp gauge with a warning light to come on if the temp gets too high and I need to stop. Thinking using just one electric fan to pull air off the radiator.
    #69
    Sep 2017
    Lincoln, Nebraska
    So, I've found the outer stub axles for my cv axles, however the problem I'm now having is trying to locate the wheel hub and bearing assembly. I can find ones from newer VW, but not the 1971-1980 generation at all. So before I pull the trigger and buy the factory style stub axles, I'm contemplating a different approach or several.
    1. Locate the factory hub and bearing assembly
    2. Have stub axles made that are for a 1" or 1 1/4" keyed axle and just use go kart 4on4 axle hubs and use a 4 bolt pillow block bearing.
    3. Locate a Type 1 to 930 adapter stub axle set and try to locate 930 wheel hub and bearing assembly (if one even exists)
    4. Or just bite the bullet and spend the $300 and buy a pair of 930 cv axles.
    With how popular it is to take a classic beetle and turn it into a Baja Beetle, one would think that finding this hub assembly would be easy, even with the many aftermarket companies out there that build conversion kits. I guess they assume that the bearings never go bad?
    Someone told me to check on the German half of ebay and use 1303 (model number), Radlager (wheel bearing), Radnabe (wheel hub), however doing so, only showed up with model VW bugs (toy size) and newer wheel bearing and hubs for newer VW vehicles. So I'm coming up empty handed at this point. Thoughts on this? What have others used that will work out in my case?
    #70
    What stub axle and cv setup ya using. Sorry didn’t read all back thru the pages.
  1. U-Joint Spline axles (drive axles)
    Last Post: 02-01-2015, 07:34 PM
  2. VW Axles and matching hubs or similar stock axles
    Last Post: 12-10-2009, 08:41 PM
  3. Need Help With Axles
    By millfab313 in forum Driveline
    Last Post: 06-05-2009, 03:41 PM
  4. Where to buy these axles?
    By Antony250R in forum Driveline
    Last Post: 02-01-2009, 03:10 PM
  5. Axles
    By boostinjdm in forum Driveline
    Last Post: 08-09-2008, 08:01 AM
