Page 3 of 9 FirstFirst 1 2 3 4 5 ... LastLast
Results 21 to 30 of 86
    Re: Inadequate cv axles?
    #21
    Sep 2017
    Lincoln, Nebraska
    The Extreme Baja Karts look pretty cool. However, getting a CVT that works well is not cheap. I've been pricing them out for a few months and they run $300+ per pulley and finding a belt isn't easy. Which is why I'm wanting to go with a motorcycle engine. I have looked at buying a complete snowmobile and pulley the engine and CVT out of that to do this, however they are not common here in Nebraska, I would have to ask my family in Minnesota to help look.
    Those who have run a CV axle rear end, how narrow of a spool can you realistically make from hub to hub for the axles to bolt up to? If I cannot make the rear track width to be less than 60", I may just sell the CV axles I have and go with a swingarm rear end and just deal with the lack of ground clearance. It looks like to make the axle tube for a swingarm is mainly just pipe with bearings on the inside.
    #22
    Jun 2015
    Texas Panhandle
    If you're going to bail on the axles then do dual swingarms and ground clearance isn't an issue. I had something like 22" of centerline ground clearance on my GK13.
    #23
    Sep 2017
    Lincoln, Nebraska
    When I get more parts and a garage/shop to build this thing in, I'll know if I am going to keep the axles or if I'm going a different route. That picture is a bit blurry, but it looks like the brake calipers are on the inside of the sprockets, then there's some sort of rounded box hooked to the trailing arms?
    #24
    Jun 2015
    Texas Panhandle
    The hubs on those swingarms are eccentric...you rotate them to adjust chain tension. The calibers are inboard of the sprockets.
    #25
    Jun 2015
    Texas Panhandle
    #26
    Sep 2017
    Lincoln, Nebraska
    The background words on it make it difficult at first, but looking at it closely it makes sense. I did look up an ecentric wheel hub and that also kind of explained more on how to do it a bit. Would be easier than a spring tensioner with a sprocket.
    #27
    Jun 2015
    Texas Panhandle
    oooh these are from roketa's site...didn't think they'd still be up
    Same type of drive setup on a full size buggy: https://www.youtube.com/watch?v=SCfjahnGgDg
    #28
    Jun 2015
    Texas Panhandle
    Absolutely it is better than a tensioner. I hate tensioners...one more thing to fail. The GK13 driveline is one of the very few things China got right with their minibuggies.
    #29
    Sep 2017
    Lincoln, Nebraska
    I cannot tell by the pictures, but the chain appears to be around the #420 and #428 size rather than #520 or #530 chain used on bikes and quads.
    #30
    Jun 2015
    Texas Panhandle
  1. U-Joint Spline axles (drive axles)
    Last Post: 02-01-2015, 06:34 PM
  2. VW Axles and matching hubs or similar stock axles
  3. Need Help With Axles
    By millfab313 in forum Driveline
    Last Post: 06-05-2009, 02:41 PM
  4. Where to buy these axles?
    By Antony250R in forum Driveline
    Last Post: 02-01-2009, 02:10 PM
  5. Axles
    By boostinjdm in forum Driveline
    Last Post: 08-09-2008, 07:01 AM
