Results 1 to 10 of 12
    Street bike Engine RMP reduced for a CVT
    Ok guys. All the rage these days is putting a Street bike engine in a buggy, SXS, UTV, whatever you want to call it. BUT the thing is how do you pare one to a CVT transmission? I have long thought it would be possible but haven't really seen any substantial evidence that an engine putting out this many RPM, HP, Torque can be effectively transmit the power down through a CVT. If any of you know of a real build where this has been done I challenge you to post it here.
    From my extensive reading it seems as though the issue with mating a CVT to a street bike motor (Busa, R1, etc) is these engines power band has an RPM that is way too high for any CVT out there. But what if... What if you build a gearbox, or used a chain driven Jack shaft and reduce the RPM of the engine? Sort of like this....
    Sorry for the photo of an RC buggy... I couldn't delete it so disregard.
    So what do you all think? Can it be done? Good idea, bad idea?
    Attached Files Attached Files
    Re: Street bike Engine RMP reduced for a CVT
    Better off finding a snow mobile engine that is already setup for CVT.
    Quote Originally Posted by ODB View Post
    Agreed.
    Some of the sled transplants into the UTVs are making stupid hp and don’t have all the gear box and clutch stuff in the cases. Sled engines are lighter and are designed to work with CVT clutches - it’s a win/win.
    Sep 2014
    West Palm Beach FL
    Seems a bit Rube Goldberg-ish to use a cvt with a street bike engine that already has a 5 or 6 speed transmission.
    Quote Originally Posted by LIDUNO View Post
    I completely agree with you LIDUNO. So how the heck are these guys getting these street bike engines in their buggies? Are you telling me that ALL of them have a manual transmission in them? Surely someone has successfully mated one to a CVT... no?
    Chain drive to a rear sprocket drive and shift gears.
    Sep 2014
    West Palm Beach FL
    Quote Originally Posted by 67StingrayJ View Post
    I would say most use the bike transmission. I'm sure someone out there has done it your way, but it would probably be the exception not the rule.
    Blog Entries
    1
    Does Rekluse make a clutch for those? Might be a option.
    Jun 2014
    Upper Peninsula, MI
    If you're dead set on it you might be able to lock the bike trans into one gear and remove the other unused parts of the transmission to save a little weight, but I think it probably isn't worth all that trouble.
    Sep 2014
    West Palm Beach FL
    Quote Originally Posted by 65chedderbob View Post
    I know I'm going way above what anyone would probably want to do, but he could eliminate all the gears in transmission. He could drive a cvt directly off the crank with some fabricating. Again, that's the hard way to do it.
  1. Ds650 street bike engine swap Cbr600rr
    By Ds650 in forum Motor - Engine
    Last Post: 06-05-2014, 02:50 PM
  2. Street bike engine vs. quad engine
    By manther in forum Motor - Engine
    Last Post: 03-01-2011, 07:13 AM
  3. Joyner to street bike motor?
    By cagefighter in forum Motor - Engine
    Last Post: 06-14-2010, 09:30 PM
  4. R1 Street Bike Sprocket Sizes to start with?
    By ffjosh in forum Driveline
    Last Post: 12-10-2008, 02:36 PM
  5. Street Bike or Sled
    By brett_s in forum Motor - Engine
    Last Post: 11-23-2008, 08:56 PM
