Results 1 to 5 of 5
    Is it a problem if the spool for the axles is a few inches aft of the wheels?
    Jun 2015
    Texas Panhandle
    Title says it. trying to figure out if I would need to shift my spool back or the engine forward.
    Re: Is it a problem if the spool for the axles is a few inches aft of the wheels?
    Not at all - if you think about it, other than when the axle is flat in suspension travel, it’s never aligned.
    Jun 2014
    Upper Peninsula, MI
    As long as you're not close to Max angle on the CVs or u joints (whichever you may be using) because that will increase the angle on them slightly throughout the whole travel. Wouldn't want them to bind. Other than that consideration, I think you should be fine
    Jun 2015
    Texas Panhandle
    I just didn’t know if it would cause problems with everything swinging on opposing arcs. I’m still debating whether or not to do it.
    Dec 2012
    Perth, Western Australia
    AR51 are like this stock.
  1. Help with converting decimals to inches
    By P-Dog in forum MiniBuggy.net Lounge!
    Last Post: 03-08-2013, 11:53 PM
  2. Different Motor Sizes? (In Inches)
    By TutTech in forum Motor - Engine
    Last Post: 12-11-2012, 07:42 PM
  3. rear tires wider than front.. by ..2-3 ish inches..?
    By brooksie2113 in forum Suspension - Wheels & Tires
    Last Post: 07-16-2011, 07:05 AM
  4. VW Axles and matching hubs or similar stock axles
  5. 50 inches
    By 8 ball in forum MiniBuggy.net Lounge!
    Last Post: 12-02-2009, 08:53 PM
