Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 21
    Sprockets and Chains
    Jan 2015
    Norco, CA
    Ok, how to make them last in the sand? my last sprocket lasted 2 weekends, Sprocket Specialties, aluminum, will a hard anodize make it last longer, chains, what lube to use? what is the recommended chain?
    my car is fairly heavy hayabusa powered EBK, I like to drive it hard.
    Re: Sprockets and Chains
    Use steel
    Are you running o-ring or x-ring chains? O-ring chains won't necessarily make your sprocket last longer, but they'll handle the sand and the articulation heat much better. The lubrication stays inside the o-rings, so lubrication (theoretically) isn't necessary.
    Also, are you running a 520 or 530 sprocket setup?
    Jan 2015
    Norco, CA
    530, I believe it is an X ring, shouldn't the x-ring actually be better than o-ring, as they have 2 seals?
    Jun 2014
    Upper Peninsula, MI
    X ring chain has less friction than an o ring chain and theoretically keeps grease in and dirt out better than an o ring chain does. Steel sprockets should last a good bit longer than aluminum ones
    Dec 2012
    Perth, Western Australia
    I run an ebay window washer bottle full of transmission fluid. When I hit the button it gives a squirt of lube to the chain. Messy but works very well.
    Look at SuperSprox's Stealth line. Thus far these have proven to be the most reliable, longest lasting sprockets I've ever used. Don't skimp on the chain either - Regina Gold, the upper end DID, Renthal - all top quality.
    The EK zvx3 is a step ahead of both the top RK and DID chains. The internal friction must only be half of others, and it doesn't stretch.
    I cooked multiple DID ZVMX chains before switching. A couple hundred miles at 80mph, and they would turn blue. I have over 500 on the EK chain, with only 70 links around 17t sprockets on an rpm gearbox, and it looks great. I've never touched the chain tension since install, which is impressive.
    Senior Member Beruba's Avatar
    Feb 2014
    Alberta Canada
    Good to know I just ordered a EK zvx3 my set up is similar to yours 68 links 18t sprockets. I also have the same over heating issue at high speed. I ordered the 140 link chain and a couple extra master link that will give me a spare chain.
    It runs much cooler than any other chain. It will get hot, like 140F, but nothing like the hand searing temps I used to see...
    I did the same, bought a 140 link, split it in half, and bought another master link. Made two chains, and kept one in the box as a spare.
  1. Clutch for chains
    By Priyank in forum SAE Baja
    Last Post: 06-20-2012, 03:03 PM
  2. Chains & Sprockets
    By TutTech in forum Driveline
    Last Post: 01-15-2012, 06:24 PM
  3. Short chains and small front sprockets...
    By avendlerdp in forum Driveline
    Last Post: 11-14-2008, 01:57 PM
  4. 525-530-630 chains sprockets
    By enroffroad in forum Driveline
    Last Post: 11-06-2007, 12:27 AM
  5. Sprocket and Chains
    By BoneDuner in forum Driveline
    Last Post: 12-18-2006, 10:02 AM
