Results 11 to 20 of 21
    Re: Sprockets and Chains
    Jan 2015
    Norco, CA
    do you oil your chain?
    PJ1 blue label before each trip. I usually get 250-300 miles per trip, then use maxima chain cleaner after to get the sand off, and relube.
    The lube is more for the external rollers and keeping the o rings from drying out
    Jan 2015
    Norco, CA
    got this message today from SuperSprox
    "We don’t have any sprockets for that application, sorry.
    Thanks,
    Craig Nadeau
    Sales Account Manager
    Toll Free (800) 328-5454, Ext. 536
    Direct (763) 255-2536
    cnadeau@arrowheadep.com
    I replied that I saw on their site they go up to 70 tooth sprockets, mentioned again that it was a 530 and asked if they make any custom, I'll let you know what I hear back, Sprocket specialties can make me a custom sprocket and have it delivered in about 3 days, but that's aluminum, non anodized.
    Well that sucks!
    check Krause racing and see if they offer something similar (curios... I think Krause gets them from S Sprox)
    Well, Kuma, your experience may help out the rest of us. I'm looking at a similar application, where I was planning on running a short 520 chain to a rear custom sprocket from Sprocket Specialties. My application is only 50 horsepower, so maybe I won't have the same issues, but I've decided that I need to run a 530 chain, so I should probably pay closer attention to the sprocket that I order. And, the chain.
    Jan 2015
    Norco, CA
    Sprocket Specialties has been excellent in their customer service, a hard anodized sprocket may have lasted longer, not sure if they make steel, maybe I'll check into that after this post.
    I heard back from SuperSprox, they sent me a sheet to fill out with the specifics , bolt circle, bolt size and type, I'll take some measurements this weekend and see if they can help me or not, I'll let you know how it pans out.
    I'll 2nd this chain! 1 adjustment after initial breaking in, not again. turboed zx12 1100lb car
    Got a member to cut sprocket from some crazy steel for ind machine. No wear at all, and you better not need to drill a hole in it!
    Jan 2015
    Norco, CA
    how do I get one of these sprockets?
    Contact Jersdunz here on the board.
    Jan 2015
    Norco, CA
    Quote Originally Posted by CARLRIDDLE View Post
    Started a new thread, hope he sees it.
    https://www.minibuggy.net/forum/drive...tml#post328140
  1. Clutch for chains
    By Priyank in forum SAE Baja
    Last Post: 06-20-2012, 03:03 PM
  2. Chains & Sprockets
    By TutTech in forum Driveline
    Last Post: 01-15-2012, 06:24 PM
  3. Short chains and small front sprockets...
    By avendlerdp in forum Driveline
    Last Post: 11-14-2008, 01:57 PM
  4. 525-530-630 chains sprockets
    By enroffroad in forum Driveline
    Last Post: 11-06-2007, 12:27 AM
  5. Sprocket and Chains
    By BoneDuner in forum Driveline
    Last Post: 12-18-2006, 10:02 AM
