Page 2 of 2 FirstFirst 1 2
Results 11 to 15 of 15
    Re: Rear spool for son's buggy
    Dec 2015
    Near Pittsburgh, PA
    That is my cheap setup...more vids with the buggy actually moving.
    This is a low budget woods machine and not a high dollar sand toy.
    For my area, it would make more sense to buy a 4x4 side by side if I was going to spend big money.
    Hey Protodie - how long are you planning to run your sale? Also, does your front wheel kit include the caliper?
    S.W. Michigan
    Quote Originally Posted by pploco View Post
    sale will probably run another 2 weeks yet
    yes, caliper and pads and 5/8 heims are included with each kit
    I think this is the direction I'll go. It would save me a ton of time and scavenging headaches. I'm heading out of the country today for work and will be back on the 6th. I've got two wheel kits and a live axle sitting in my cart.
    What is the length wheel to wheel with your wheel kit and live axle?
    S.W. Michigan
    the sale going until Feb 5 LOL,,, just kidding
    I will keep it going until Feb 10
    on the rear,,,
    with 17 1/2" axles, our A arms , live axle,,,wheel kits and the wheels we run etc,,, outside of tire to outside of tire measures 68"
    with different offset wheels it can be 64" wide
    our Front ends are 70 to 72" wide outside of tires.
    it is better to have the front end slightly wider than the rear.
    This helps the front traction over power the rear and turns / corners better
  1. Adjustable Rear Spool With Brake, Who Makes One?
    By GR8WHITE in forum Driveline
    Last Post: 11-04-2010, 02:32 PM
  2. in need of a spool
    By hskers82 in forum Driveline
    Last Post: 09-01-2008, 08:52 PM
  3. Spool
    By LockedupXJ in forum Driveline
    Last Post: 08-27-2008, 07:52 PM
  4. drive spool
    By Bugpac in forum Driveline
    Last Post: 03-28-2006, 07:41 PM
  5. rear spool
    By hotwheels000 in forum Driveline
    Last Post: 01-29-2006, 11:24 AM
