Page 2 of 2 FirstFirst 1 2
Results 11 to 13 of 13
    Re: Stub Axles?? Bearings??? Need help from someone with experience...
    Dec 2012
    Perth, Western Australia
    Quote Originally Posted by deaner View Post
    Yup. F150 outer CV stub fits right into intrepid hub. Strong, simple, cheap. F150 axle is "standard" 28 spline, same as 930. F150 inner could work also, has 6 bolt flange, $600 for all CV's, axles, and hubs, all new.
    Apart from RickS is there anywhere to buy the CV on its own? I thought the issue was they came as a set, inner and outer Cv and axle??
    Senior Member deaner's Avatar
    Sep 2011
    Northern Ohio
    So cheap, throw the rest in the scrap dumpster.
    I'm planning on doing as you said deaner on my st4. I already piked up some intrepid hubs and will be going to the scrapyard to get the cv's. What year f150 fit the intrepid hubs? Also is it possible to lengthen the shaft using a sleeve?
  1. Type 1 CV Flange/Cups for Stub Axles and Drive Shaft
    By darwinpayne2000 in forum Driveline
    Last Post: 01-19-2010, 07:38 PM
  2. REQ: stub axles, cv joints
    By kevlar129bp in forum File Library
    Last Post: 09-09-2009, 07:09 AM
  3. Stub Axles
    By dodgewade in forum Driveline
    Last Post: 04-03-2008, 05:02 PM
  4. tapered bearings for rear stub carrier?
    By hero_saku39 in forum Driveline
    Last Post: 11-14-2007, 06:24 AM
  5. Stub axles
    By sprockett in forum Suspension - Wheels & Tires
    Last Post: 11-08-2005, 09:38 AM
