Results 1 to 5 of 5
    Chain driver conversion
    New to the forum was just wondering if this differential would be good to convert to chain drive.
    http://www.ebay.com/itm/MK4-VW-TDI-J...NXuetk&vxp=mtr
    Re: Chain driver conversion
    Welcome to the site!
    Would you weld the body shut and make it oil tight?
    I've been reading lots of articles on what/how to do that but yes weld or make a sleeve to cover the open part.
    I'm planning on doing the same thing with a Volkswagen Beetle differential. I'll seal it up, but I'm planning on using grease instead of oil. I suspect that oil would leak out around the shafts. Also, a Comet differential uses grease, so it should work.
    Issue I found was sourcing bearings. But sure if close you could machine a bit from ends for bearing to ride. The cv shafts? Do they fit a common cv or gonna use ones from car? With enough machine time and welder most anything could work!
    Or heres a drop in ready setup I have for sale. https://www.minibuggy.net/forum/sale/...ive-spool.html
  1. Driver size limit for Velociraptor
    By vegasloki in forum Badland Buggy Group
    Last Post: 08-15-2012, 08:26 PM
  2. ST4 driver's legspace...
    By Binze in forum ST4
    Last Post: 12-23-2011, 08:27 PM
  3. New buggy driver from Fresno, ca.
    By 2smoker in forum The Welcome Mat
    Last Post: 06-21-2011, 04:14 PM
  4. 2011 Dakar Champion driver- Protolite Race buggies
    Last Post: 03-23-2011, 09:53 AM
  5. CVT Driver/Driven Clutch Orientation
    By darwinpayne2000 in forum Driveline
    Last Post: 01-27-2010, 06:35 PM
