Results 1 to 6 of 6
    CVT With a Driveshaft
    Do any of you know of an ATV with a CVT that uses a drive shaft to drive a rear differential. I have a Acro quick change rear end (http://www.acroracing.com/4-Bolt.html) that I would like to pair with a large displacement ATV engine and the matching CVT.
    Re: CVT With a Driveshaft
    I don't know for sure, but I believe the 2000-era Polaris Sportsman ATV's used a drive shaft instead of a chain.
    Edit: I took a look at a parts diagram for the 2007 Polaris Sportsman 700 and it shows a front and rear driveshaft with U-joints.
    Jun 2014
    Upper Peninsula, MI
    I think a Yamaha Grizzly does as well
    Grizzlys do use a driveshaft. We have a 450, the ultramatic clutches are pretty nice as well, there is a centrifugal clutch driving the cvt clutch, so the belt is squeezed a little tighter than normal.
    The Arctic Cat V-twin is the one notable that comes to mind that does NOT have a shaft driven rear. The engine includes a transaxle , with a shaft output for the front.
    • Engine - 2016 RZR 1k XP
    • Transmission - RZR 1k XP
    • Chassis - 2012 RZR 570
    • Suspension -
    kawasaki 700 kfx does I believe. I want to use this a power plant for a small trail rig for my daughter some day....
  1. Can you run a single driveshaft off of RPM?
    By rgvkid in forum Driveline
    Last Post: 02-26-2013, 06:08 AM
  2. CV's OR CHAIN DRIVEN DRIVESHAFT???
    By FullThrottleKTM in forum Driveline
    Last Post: 04-04-2012, 08:44 PM
  3. Driveshaft in A arm
    By sledhead21 in forum Driveline
    Last Post: 11-08-2011, 05:59 PM
  4. Fl350 driveshaft help
    By guitar1234 in forum Honda's Pilot & Odyssey
    Last Post: 07-13-2010, 08:17 AM
  5. driveshaft length???
    By The Kar Audio Guy in forum Driveline
    Last Post: 10-21-2008, 08:24 PM
