Results 1 to 7 of 7
    How do I get the travel I want with a FWD GM 3.8l V6?
    Jun 2015
    Texas Panhandle
    So a local has a 2003/4 Pontiac Grand Prix that runs and drives, but is rather a complete wreck and disaster, for $400. I am rather fond of that engine and am trying to figure out how I can use it with my chassis (Roketa GK-34).
    The problem that I'm having is that the transmission outputs are nearly as far apart as my trailing arms. My current track is about 56", 8" narrower than the Grand Prix's and the car uses these super short stubby axles.
    Is there some magic way of making this transmission work with my 10" of travel in the back without having to make the rear eight feet wide?
    Re: How do I get the travel I want with a FWD GM 3.8l V6?
    Sep 2014
    West Palm Beach FL
    Don't remember the thread, but there was a 4 wheeler with a swing arm, and A arms.
    Sep 2014
    West Palm Beach FL
    I couldn't find it, but imagine your engine, and transmission, on a swing arm. The A arms would move and so would the swing arm.
    Bend-Tech Dragon Master
    Nov 2009
    They just don't go with minis, Size-weight-gearing.
    You don't want to deal with 800lbs of motor and trans on a suspension arm.
    Jun 2015
    Texas Panhandle
    Yeah the swingarm/a-arm combo I don't think would work here. Or at least not ideally and it wouldn't allow me to use my shocks.
    I think I have to abandon the idea by weight alone. As much as I like the 3.8l it is a 690lb long block, plus the weight of the transmission. I wouldn't be able to use it without EXTENSIVE redesign of the rear suspension and chassis. I need to focus on finding and blowing the Geo G10/G13 as I originally planned.
    Senior Member deaner's Avatar
    Sep 2011
    Northern Ohio
    The engine is not the problem, it's the automatic transmission. They wrap around the engine and are very wide where the CV shafts attach. Go with a manual transmission. A Muncie 282 or an F23 will bolt to the 3800 with minimal work. These trans are very narrow and have many shafts of differing lengths that "snap" right in.
    Jun 2015
    Texas Panhandle
    It became less about the width of the transmission and more about the weight.
    It's all good, though. I have a '91 Geo G10 now, though, and I plan on running about 10psi on it...that'll get me around the horsepower I want and it'll be an easy engine to cram in the chassis.
  1. Mid Travel car - how much better is long travel?
    By ranamuck in forum Show off your toys in here!
    Last Post: 05-08-2012, 11:12 AM
  2. travel
    By turbotike in forum Suspension - Wheels & Tires
    Last Post: 04-03-2012, 12:25 PM
  3. 400 mm travel
    By willysp in forum Suspension - Wheels & Tires
    Last Post: 02-02-2010, 02:51 PM
  4. how much travel?
    By 455bird in forum Suspension - Wheels & Tires
    Last Post: 05-12-2008, 10:48 AM
  5. Shock travel mod
    By masterfabr in forum Suspension - Wheels & Tires
    Last Post: 02-15-2007, 11:17 PM
