Results 1 to 7 of 7
    Reverse box lube pump
    Telescope Master
    Aug 2009
    Tucson, Az
    I've been thinking about adding a small lube pump to my reverser box. I kinda remembered KFab had one for one of his projects but I can't find the info. Anybody out there got suggestions? JD66, was there a pump in the stuff you got from KFab?
    If the best things in life are free why are there lotteries?
    Re: Reverse box lube pump
    Oct 2009
    Hit up Jersdunz he just finished his RPM with a pump . He used a scavinger pump from a rear mount Turbo off a snow machine.If I was to mount a pump on mine thats prob to pump I would try . Boondockers & MPI and a few other sell rear mount kits for the Apex and Nytro sleds.
    Senior Member JD66's Avatar
    Jan 2013
    San Diego, CA
    Hey Doc, yes the box I picked up from K-fab came with a pump. Here are a few pictures - I remember Richard saying the pump guy was excited about the application. I'm thinking I'll run this pump on the tazcar in the next year or so.
    those are diff pumps like used in Nascar.
    Oct 2009
    That's a sweet pump but the turbo return oil pump is a lot simpler . It is powered with 12v
    I'm sure Jeremy will see this post and have something to add. That pump he added is loud, course you can't hear it over the car running....
    Telescope Master
    Aug 2009
    Tucson, Az
    The HTP is the one I was looking for. Thanks to all for the help.
  1. Water Pump Impeller Fouling pump casing?
    By tbwcurtis in forum Motor - Engine
    Last Post: 04-25-2012, 02:28 AM
  2. What is the best chain lube?
    By jgp in forum Driveline
    Last Post: 01-05-2012, 03:45 AM
  3. Chain Lube
    By buggito in forum Driveline
    Last Post: 07-20-2007, 01:11 PM
  4. Lube it or Lose it?
    By BoneDuner in forum Motor - Engine
    Last Post: 01-13-2007, 07:52 AM
  5. cv lube
    By masterfabr in forum Driveline
    Last Post: 08-19-2006, 02:56 PM
