Results 1 to 4 of 4
    I need some pulleys.
    Jun 2015
    Texas Panhandle
    I need to find some v-belt pulleys and all the luck I'm having are some very heavy, huge things. I'm wanting to find stamped steel ones that I can weld to my existing pulleys. I'm needing to find some smaller ones...4" or so on the outside...and then some 2.5~3x larger.
    I think I can source some from second gen RX-7's...I use to have piles and piles of them...but am not 100% sure of the their size. I'd like to hear of any other sources I can get my hands.
    Re: I need some pulleys.
    Have you looked in McMaster-Carr?
    Weasler has a bunch of stamped steel pulleys. My local tractor supply company has them in stock, and they are made to weld onto hubs.
    Jun 2015
    Texas Panhandle
    I haven't looked too extensively because my project has taken a bit of a turn...luckily I hadn't committed to anything yet.
    I'm going to go through the pulleys at TSC...my stores only had cast iron ones. They may work for me now, though. I didn't want to add 10lbs of steel to the crank to get a set of pulleys.
