Results 1 to 10 of 17
    Odyssey center carrier?????
    Sep 2014
    West Palm Beach FL
    Anyone ever made a center carrier out of an odyssey lower gear shaft?
    I'm thinking the stock disc in the stock location[Larger splines on the right]and a sprocket mounted to the gear? Any thoughts?
    Got this pic from google.
    Re: Odyssey center carrier?????
    Sep 2014
    West Palm Beach FL
    Well I just figured out something good. The rear disc mount from a raptor 660, will slide right onto the splines where the gear is in the photo. That should make it easier to mount a sprocket
    I also realized the hubs from the raptor 660 fit the fl350 axles with a spacer. This means I can use the raptor wheels and tires I have.
    Senior Member turbomike9's Avatar
    Oct 2014
    WI
    If your going to do that why not use the whole odyssey transmission? Seems the prices aren't too bad on ebay these days for a complete one.
    You plan to use the odyssey axles? What is the powerplant and suspension for this buggy?
    Edge Piranha with Sled Engine, 2 Margay sprint race karts, and a couple of fun Karts
    Sep 2014
    West Palm Beach FL
    I got a Raptor 660 with reverse I was thinking about using. The suspension is stock FL350 at the moment. The FL350 itself has been raped for parts since the original owner blew the motor.
    Sep 2014
    West Palm Beach FL
    The reason I was considering using this shaft is because it has the correct spline for the ody axles and it's the correct length.
    I was thinking pillow blocks for mounting but the metric size of the shaft seems to have squashed that idea. I found sealed bearings to fit but might have to custom make some 4 hole bearing mounts.
    Bearing part numbers are 6206 2RSJEM and 6207 2ZJEM. They're made in the USA by SKF. About 75 bucks
    My buggy runs an odyssey reduction box, with the output shaft set up to take VW CV flanges...not much luck uploading pics here but I can PM.
    Quote Originally Posted by LIDUNO View Post
    Why not take the shaft down to a local machine shop, have the turn the shaft down to the correct size for a given pillow block?
    Sep 2014
    West Palm Beach FL
    Quote Originally Posted by Rcn11thacr View Post
    I have a lathe but I wanted to keep the size stock. It all worked out, but I sold the buggy after a chain saw accident. It's been about a year and my hand is just now about 70%
    Oh, my bad. I didn't realize I'd replied to an old thread.
    Sep 2014
    West Palm Beach FL
    Bull mentioned his Photobucket account was working again, so I figured I would give it a test. These were my feelings for Photobucket..lol
  1. Center Carrier Question
    By Trell1245 in forum Driveline
    Last Post: 05-27-2014, 09:55 PM
  2. Low HP IRS center carrier
    By Snoopy in forum Driveline
    Last Post: 06-12-2013, 07:20 AM
  3. Center Bearing Carrier
    By butch in forum Driveline
    Last Post: 01-03-2011, 09:50 AM
  4. Center Carrier
    By PITTduner in forum Driveline
    Last Post: 03-11-2007, 07:39 PM
  5. center carrier width
    By Lonuf in forum Driveline
    Last Post: 10-31-2006, 08:34 AM
