Thread: RPM mods
Page 2 of 2 FirstFirst 1 2
Results 11 to 18 of 18
    Re: RPM mods
    Senior Member whitedragon64's Avatar
    Oct 2008
    Perth Australia
    Yes mate and it will take the thrust loading much better , These box's are filled to the top and then a breather tube ran up to a Catch can so lubrication isnt the issue, These 2 RPM boxes are powered by ZX1400's and raced out here in Oz (Goose Racing) so they take a beating and with larger balls and not rollers there will be less ball speed = less friction = less heat build up too
    Re: RPM mods
    Oct 2008
    Perth Australia
    Time will tell I guess, its doing a desert race today and at 120 km long laps so will see if it comes home ???
    Re: RPM mods
    Cooling is a lot easier to deal with than flex.
    Re: RPM mods
    Oct 2008
    Perth Australia
    Thats very true well its made it through the first days racing was clocked at 176 Kmh down one of the straights ( radar gun ) Fastest speed was a Pro Buggy 219 Kmh
    Re: RPM mods
    Crickey! That's almost 140MPH. Post up some video.......
    Re: RPM mods
    Most are not running those speeds for that distance. I’d say heat in that box is cooking oil n bearings. A ext cooler n pump returning fluid to input bearing area.
    I also really like the 3rd bearing on outside of input shaft.
    Re: RPM mods
    Oct 2008
    Perth Australia
    Yeah that’s the main issue with the RPM s that the guys are having I have hit these rpm box’s with temp gun and seen 110 deg C
    but he finished the race 400 kms and came 2nd in class The class winner running full size car with 3.5 litre
    In my box I now run is fitted with external pump through an oil cooler with thermo controled switch for the fan along with a temp gauge so I can monitor the temps and havernt seen it rise above 80 deg C
    Re: RPM mods
    110C=230F Not all that bad. I wouldn't worry to much until 122C. The diff's on our race trucks routinely see 150C.
    Outboard support bearing sounds like a winner. Would take all the flex out of it. Similar to what we used to do one the KZ1000 drag bikes. They got an outer bearing on the countershaft to keep it from twisting off.
  1. Protolite 450 mods
    By TALON in forum Projects in Progress
    Last Post: 09-02-2014, 10:36 AM
  2. Central Texas FL350 Build, Frame Mods, ROTAX 670, A-Arms, etc etc
    By KMKUSTOMS in forum Projects in Progress
    Last Post: 06-05-2014, 11:20 AM
  3. 08 Busa questions? mods?
    By JayPeeYooEssAy in forum Motor - Engine
    Last Post: 10-28-2010, 12:27 PM
  4. help with small engine mods
    Last Post: 12-02-2009, 05:51 PM
  5. performance mods 4 raider max
    By krazydude in forum Motor - Engine
    Last Post: 10-28-2007, 11:01 AM
