Results 1 to 10 of 39
    RPM Gearbox assembly
    Nov 2007
    Fort Worth Texas
    Install drive shaft seal
    Re: RPM Gearbox assembly
    Nov 2007
    Fort Worth Texas
    put oil on bearing in case
    Nov 2007
    Fort Worth Texas
    put output drive shaft in bearing
    Nov 2007
    Fort Worth Texas
    put the middle gear stack into case. There is a shim on both sides of the gear stack. It would be best to put grease on the shims to keep them in place. The side of the gear stack that goes into the case has a lip on it. The shim needs to against the gear and not below the lip. If you get this wrong the gear stack will set to high and the gearbox will not shift and the gears will rub on there sides.
    Nov 2007
    Fort Worth Texas
    put the drive gear on the drive shaft
    Nov 2007
    Fort Worth Texas
    put the shaft for the top gear stack in the case
    Nov 2007
    Fort Worth Texas
    put the alum spacer on the to top gear stack shaft
    put the slim on to top of the alum spacer
    Nov 2007
    Fort Worth Texas
    put top gear stack in case
    Nov 2007
    Fort Worth Texas
    put shim on top of gear stack
    Nov 2007
    Fort Worth Texas
    Make sure the shims are on top of gear stacks
  1. How I installed my RPM gearbox in my buggy
    By stress in forum Driveline
    Last Post: 11-21-2014, 03:08 PM
  2. Minibuggy FNR gearbox / transmission market
    By ihcj9 in forum Driveline
    Last Post: 01-22-2012, 06:15 PM
  3. Gearbox Decisions
    By rhino1598 in forum Driveline
    Last Post: 07-17-2011, 11:16 AM
  4. Tl 1000 engine to toyota mr2 gearbox.
    Last Post: 09-29-2009, 06:40 AM
  5. 6 Part Forward Reverse Gearbox
    By tooltime in forum Driveline
    Last Post: 07-02-2008, 09:16 PM
