Results 1 to 10 of 13
    Gearing Chart for you guys to use
    Laguna Niguel, Commifornia
    Here is a gearing Excel chart that Tenaja posted on my single seater thread years ago. I just used it again for my next project and thought you guys might like it. It's very easy to use. Just plug in your primary ratio, your transmission ratios, gearbox and sprocket ratios, tire height, and engine RPMs and it spits out all your speeds in KPH and MPH. I added a few cells to simplify the final ratios when using a FNR box. If not using a FNR box, simply put "1" under the gearbox ratio and put in your sprocket numbers. The file attached has the info for my ZX14 which I left on to serve as an example. Hope you guys like it.
    PS: If it's been posted before, feel free to remove. If not, it might make a good Sticky. It seems pretty accurate from what I've experienced.
    Re: Gearing Chart for you guys to use
    Jan 2009
    Los Angeles
    Awesome, Thanks Flyer!
    Finally discovered the root of the main issue plaguing me (huge split between first and 2nd gear for the '85 vs '86 engine) this is very much welcome. Wish i had thought along these lines earlier!
    Can someone check this? Im getting a bunch of jibberish when I open it.
    Prolly my puter.
    Right click, save as. If you just open it, it does the jiberish.
    Thanks boss.
    HOLY Awesome Spreadsheet!!
    Couple this with gearingcommander.com
    and you got all the data you could want to set up an mc car..
    Mar 2012
    Wellington, New Zealand
    Quote Originally Posted by flyerrider View Post
    Hey Guys,
    Any idea where the attachment has gone?
    Cheers.
    Senior Member Beruba's Avatar
    Feb 2014
    Alberta Canada
    Mar 2012
    Thanks Beruda.
  1. Need gearing advice.
    By Railguy in forum Driveline
    Last Post: 09-11-2013, 04:22 PM
  2. Rules That Guys Wish Girls Knew
    By opsled in forum MiniBuggy.net Lounge!
    Last Post: 06-24-2011, 05:31 AM
  3. Gearing question & Gearing Calculator
    By RDRacing647 in forum Driveline
    Last Post: 06-22-2011, 05:32 PM
  4. Questions For You Boosted Busa Guys?
    By GR8WHITE in forum Motor - Engine
    Last Post: 10-02-2010, 08:29 PM
  5. Hayabusa MPH Gearing Chart
    By HarveyMushman in forum Motor - Engine
    Last Post: 02-28-2007, 10:58 PM
