Page 2 of 2 FirstFirst 1 2
Results 11 to 13 of 13
    Re: Gearing Chart for you guys to use
    Jan 2016
    Ohio, which is a long way from the desert
    Can anyone explain what the RPM ratio input is supposed to represent? Is it for FNR gearboxes like mentioned above?
    Senior Member Beruba's Avatar
    Feb 2014
    Alberta Canada
    Yes its the ratio of the RPM gear box if you don't have one put 1 it should work for you.
    Jan 2016
    Great Thanks!
    I come from the automotive world and keep thinking I need less gearing. I am not used to spinning these little engines to 10k + rpms!
  1. Need gearing advice.
    By Railguy in forum Driveline
    Last Post: 09-11-2013, 04:22 PM
  2. Rules That Guys Wish Girls Knew
    By opsled in forum MiniBuggy.net Lounge!
    Last Post: 06-24-2011, 05:31 AM
  3. Gearing question & Gearing Calculator
    By RDRacing647 in forum Driveline
    Last Post: 06-22-2011, 05:32 PM
  4. Questions For You Boosted Busa Guys?
    By GR8WHITE in forum Motor - Engine
    Last Post: 10-02-2010, 08:29 PM
  5. Hayabusa MPH Gearing Chart
    By HarveyMushman in forum Motor - Engine
    Last Post: 02-28-2007, 10:58 PM
