Results 1 to 7 of 7
    930 CV joint bolt torque ?
    Nov 2007
    Fort Worth Texas
    930 CV joint bolt torque , (3/8 -24 thread) ?
    Gear One calls out 90 ft-lbs torque with blue loctite for the CV bolts on there Center Board Hubs. I used this on my Center Board Hubs and the bolts have never came loose.
    On the CV bolts that go into the drive flanges at the transmission, I used 65 ft-lbs torque and red loctite.
    The following is drive flanges I have:
    40 Spline Adapter Chromoly Drive Flange For Type-2 Bus 091 Or 094 Transmission To A Porsche 930 Cv
    The bolts keep coming loose.
    When I looked on the Web people are using between 40 ft-lbs to 65 ft-lbs torque, some use no loctite, some use blue loctite, some use red loctite on drive flanges like mine.
    I thinking about using 90 ft-lbs torque on the CV bolts in my drive flanges, I do not know if the drive flanges can hold up to a 90 ft-lb torque. Has anybody used 90 ft-lbs torque with this kind of drive flange?
    Re: 930 CV joint bolt torque ?
    90 ft-lbs on a fine thread 3/8 bolt? What bolts are you using? They must be 250 ksi or better. I am typically around 40. Astm calls out 37 lubricated to 50 for dry bolts to reach the 75% clamp load for a grade 8. Proof load is 90% of the bolts strength, but should only be used for single use fasteners.
    I use a green loctite from Case, and it is listed as extra heavy. I have not had them come loose yet. It forms a more flexible bond than typical loctite, and is made for heavy vibrations.
    Blog Entries
    1
    Depends on the bolts. What ever the max torque is for the bolts you are using + red locktite or even better, Vibra-tite and safety wired.......
    I've always torqued to 40 and used red loc-tite (grade 8 bolts)
    Make sure your threads are clean. Every time I grease my cvs I always get it in the bolt holes, which then ends up on the threads. Clean it out, shoot the threads with a healthy dose of carb cleaner, then put a drop of loctite on. Too much loctite won't help. If the red doesn't do, it is time to safety wire.
    Nov 2007
    Fort Worth Texas
    I going to try some Stage 8 bolts for CV joints
    #8323 CV JOINT 3/8-24 X 2 1/2 | Stage 8
    I have used Stage 8 bolts in other areas of my buggy and they stop the bolts from coming loose.
    When I get them installed , I will post some pictures.
    Nov 2007
    Fort Worth Texas
    Heres the link showing the Stage 8 bolts on my buggy
    https://www.minibuggy.net/forum/drive...ome-loose.html
  1. Micro Stub Fundamentals
    Last Post: 04-06-2015, 11:28 AM
  2. fl250 driven cam bolt question
    By Scottbrock in forum Honda's Pilot & Odyssey
    Last Post: 11-26-2011, 08:07 AM
  3. Heim/rose joint problem
    By LEE1969GB in forum Suspension - Wheels & Tires
    Last Post: 11-14-2011, 05:04 PM
  4. R1 vs. Busa
    By Andy_1972 in forum Motor - Engine
    Last Post: 01-09-2011, 07:16 PM
  5. help....u joint vs CV joint?
    By banditbuggy145 in forum Driveline
    Last Post: 04-26-2010, 09:52 AM
