Results 1 to 7 of 7
    Sway-a-way axle problems
    Nov 2007
    Fort Worth Texas
    I am helping a friend with rebuilding his buggy. We got a new pair of 28 spline Sway-a-way axles. Have 4 RCV Performance CV-joints. When we tried put the axles on the buggy we had problems getting the CV-joints to slide on to one side of each axle , they will slide on to the axle about 3/8 inch and stop, we had to use a hammer to get it off. We can get all 4 of the CV joints to slide on to one side of each axle, they slide on easy and will move on the spline very easy. When we try to slide any of the CV-joints on to the other side of the axle they go 3/8 inch on and lock solid on the axle, have to use a hammer to get them off.
    The dealer said to sand blast the spline area to get any coatings off, I also tried using a wire wheel on the spline. The sand blasting and the wire wheel had no effect.
    I know Sway-a-way is a big name in axles, do they make good stuff?
    On my buggy I used RCV Performance CV-joints and RCV Performance custom axles and every thing would side together very easy.
    Any body have any ideas of stuff I could do to get the CV-joint to slide onto the axle?
    Re: Sway-a-way axle problems
    I know I've seen BDK refer to them as Stay-away.
    Sep 2006
    Groves, Texas
    That sounds like a manufacturing problem. I would want to return and swap for an axle that is made correctly!!
    Senior Member Duane's Avatar
    Apr 2010
    Santa Rosa California
    The suggested mods by the dealer sound like a good way for them to not accept a return.
    That only apply's to there shocks.......
    Find somebody that can measure the minor and major diameter of the splines. This will tell you if they are out of tolerance or not. If they are out, call them and get a replacment set.
    I stand corrected!
    Nov 2007
    Fort Worth Texas
    To solve the problem I had to go to EMPI CVs on the end of the axle that the RCV Performance CVs would not side on to.
    I ordered the RCV Performance CVs to begin with because I had used there CVs and axles on my buggy and they worked great and I had no problems and they are American made. It took 12 weeks for them to make my custom axles.
    When I ordered the parts for my friends buggy he did not want to wait for axles to be made, so I ordered Sway-a-way axles.
    All 4 of the RCV Performance CVs fit fine on one end of each Sway-a-way axle, but will not fit on the other end of the axle. The EMPI CVs (China made) have a sloppier fit and will go onto the tight fitting end of the axle. I do not like to use stuff made in China in high stressed, loaded areas. I have seen other people buggies on this site use them and I do not see people complaining about them, so I hope it will work out OK.
    It seems Sway-a-way does not hold tight tolerances there axles.
  1. Stretch you solid axle
    By Chikin in forum How To Do It
    Last Post: 10-28-2013, 10:02 AM
  2. Axle conversion?
    By rgvkid in forum Driveline
    Last Post: 02-12-2013, 06:10 PM
  3. Center Axle Driveline
    By Airwolf450 in forum Driveline
    Last Post: 10-18-2010, 09:08 PM
  4. Replies: 11
    Last Post: 03-05-2008, 09:43 PM
  5. Help w/ cv axle measurement
    By BJSR in forum Suspension - Wheels & Tires
    Last Post: 02-06-2007, 07:27 PM
