Page 4 of 14 FirstFirst ... 2 3 4 5 6 ... LastLast
Results 31 to 40 of 131
    Re: My quick change FNR idea...
    #31
    Bend-Tech Dragon Master
    Nov 2009
    Good eye.... I think there is a 4wd version of my small front end. 100ish wheel base. The width is 80ish wide which is ok for trailers. It would be a whoop machine! Rear engine really is the best for lots of tight turning brake maneuvers.
    #32
    Hoping std rubber sealed bearings will negate extra seals for the oil bath.
    You will have to o-ring the outside of the bearings and one on the shaft too. More of a hassle than it's worth and it will probably still leak.
    #33
    Nov 2009
    Good call on o-ringing the shafts, I think we could press-fit for a decent seal.
    Bearings would be a press-fit into the aluminum, good enough for a seal.
    #34
    Nov 2009
    Yes the paddles got rotated. Refining my front end plates and some other things too.
    #35
    They will seal until it gets hot and you put power to it. Trust Me, they will leak.
    You can get bearings with an o-ring around them. For the shaft, internal washer with a large chamfer to capture a o-ring, just needs to be under constant pressure.
    #36
    Oct 2006
    Pittsburgh, PA
    You don't want to press fit both the ID and OD of the bearing. Hard to disassemble, potential to overstress the bearing causing it to wear out quicker. I would use a shaft seal, pressed in from the outside of the case, then you don't have to worry about it.
    How is that easier than just using a shaft seal? Or just lower profile?
    #37
    Curious, where do you plan on getting the splined shaft to match the QC gears?
    #38
    Quote Originally Posted by dunerocket View Post
    https://www.minibuggy.net/forum/drive...tml#post268081
    #39
    Nov 2009
    Quote Originally Posted by minibajaman View Post
    Trying to stay inside a 0.500 thick plate.
    #40
    Why?
    www.SinisterSandSports.com
    918-521-3736
  1. Camber Change vs Wheel Scrub
    By JD66 in forum Suspension - Wheels & Tires
    Last Post: 05-29-2013, 09:24 AM
  2. Cost to change ratio/quick change
    Last Post: 11-15-2012, 10:02 AM
  3. Planetary Reverse Might be a stupid Idea.
    By opsled in forum Driveline
    Last Post: 02-16-2012, 04:17 PM
  4. Quick Change gears & shafts
    By Shmeefer in forum Driveline
    Last Post: 02-22-2010, 12:10 PM
  5. Quick change rear end gears for jackshaft
    By MXman in forum Driveline
    Last Post: 10-13-2006, 08:55 AM
