Page 2 of 14 FirstFirst 1 2 3 4 12 ... LastLast
Results 11 to 20 of 131
    Re: My quick change FNR idea...
    Bend-Tech Dragon Master
    Nov 2009
    Quote Originally Posted by deaner View Post
    Wouldn't it be easier to couple it right to your RAV4 tranny? Or would the engine be offset too much?
    It would be HEAVY and ratios would be way high.
    Honestly besides time I'm sure I'll have close to rav4 transmission $ in the parts.
    <70 QC gears
    ~70 Sprockets
    <50 Bearings
    Not sure on materials, I think we some stuff laying around.
    Nov 2009
    Now it makes more sense. I would use three smaller diameter QC gears instead of chain,and maybe gears from a transmission that had synchronizers/sliders/shift fork.
    I'd need ~ 3 set of QC gears, chains are cheap.
    I could even do double row chain if needed.
    Senior Member deaner's Avatar
    Sep 2011
    Northern Ohio
    Yea, but chains need idler for tension,they stretch, and they break. Use transmission gears, they are cheap.
    Nov 2009
    Off subject but this would give 7:1 w/ my QC gears I just bought...
    1991 BMW 325i Automatic Open Differential E30 Diff | eBay
    $175 shipped w/ 6 bolt CV flanges. Love the price of BMW diffs.
    Nov 2009
    Funny you say that as all RPM setups usually use a chain.
    Its just for reverse and with turning brakes in the sand it would be just for backing out of camp/trailer... maybe the occasional deadend trail.
    Petoskey, Michigan
    The RPM's I have seen inside were all gears I believe.
    The other guy with the diff reverse box (tom pro? or???) used a chain to drive his diff setup. I know this cause I seen one break and bust out the case. It drove the diff at all times.
    EDIT: or are you talking just to drive the RPM's input?
    Sep 2011
    Northern Ohio
    Those BMW diffs are the ticket. I picked one up at a u-pull-it a few years back for a project and it was 40$ IIRC.
    I know everybody uses chains and most of them have problems with them at one time or another. Yours would be in the best possible spot for wear and tear (assuming oil bath), worst for replacing. Would it hurt to go with a 60 or 60H chain?
    Nov 2009
    Quote Originally Posted by nutz4sand View Post
    I was referring to the RPM input. The reverse chain is only used as a primary reduction where a chain box would be the secondary reduction. As again- only reverse.
    The QC gears handle big block V8s, no worries.
    Here's the latest drawing, added bearings, shift fork, etc.
    Hoping std rubber sealed bearings will negate extra seals for the oil bath. Those QC gears will move a lot of oil.
    I wonder if I make the dogs over lap the QC gear engagement it could be a FPR (F-Park-R) lol. Might help the QCs re-engage, slightly roll the car back with pressure on the lever to find mesh.
    They break because the chain is after a gear ratio from the motor to the box. They see considerably more load, and when they do break, they are under a pretty good hp load from being rapped out.
    The reverse chain designs he posted see a 1:1 ratio, they are in oil and they will only be used for backing up. I don't see how it could ever break as it will be just as strong as any chain drive reverse box setup and he will be capable of a lot more abuse than what it will ever see in reverse.
    My gearbox design is similar to this and I initially was going to use a chain for reverse, but was able to locate a 3 gear setup that is considerably stronger, doesn't require a tensioner, is cheaper than a chain/sprocket setup and i've eliminated the reverse engagement backlash, so it was a no brainier for my application.
    His chain idea, as pictured, is sound. I would just recommend running a non o-ring chain.....
    www.SinisterSandSports.com
    918-521-3736
    My reverse design looks like a flip phone and you hold it up to your mouth and say "beam me back ____ feet" and it converts you and your car into sub-atomic particles, moves it to the new location and re-assembles it. No chains involved at all!
  1. Camber Change vs Wheel Scrub
    By JD66 in forum Suspension - Wheels & Tires
    Last Post: 05-29-2013, 10:24 AM
  2. Cost to change ratio/quick change
    Last Post: 11-15-2012, 11:02 AM
  3. Planetary Reverse Might be a stupid Idea.
    By opsled in forum Driveline
    Last Post: 02-16-2012, 05:17 PM
  4. Quick Change gears & shafts
    By Shmeefer in forum Driveline
    Last Post: 02-22-2010, 01:10 PM
  5. Quick change rear end gears for jackshaft
    By MXman in forum Driveline
    Last Post: 10-13-2006, 09:55 AM
