Page 13 of 14 FirstFirst ... 3 11 12 13 14 LastLast
Results 121 to 130 of 131
    Re: My quick change FNR idea...
    Bend-Tech Dragon Master
    Nov 2009
    Putting the final touches on the model... needed chain clearance so the input plate got thicker.
    Also had to make everything fit the casting, think I got the shrink factor wrong, its huge
    But it'll work.
    Senior Member deaner's Avatar
    Sep 2011
    Northern Ohio
    Any updates?
    Nov 2009
    Casting is here... shafts are turned (balled up a bunch), trying to find mill time. Things would be moving faster if I wasn't surrounded by broken trucks.
    Jan 2013
    Sumter, South Carolina
    Any up dates? Sure does look good.
    Bump..
    Nov 2009
    Yes, I have to get back to this. MiniMax won't move without it.
    Nov 2009
    Well for those watching this thread, This box is alive and well as far as I can tell. First oil change had lots of metal, But we're think new gears and parts breaking in. Next run/dump will tell us more. No odd noises, wish I would have made a neutral spot - rolling the car to get in gear kind of sucks sometimes.
    Member 67StingrayJ's Avatar
    Jan 2019
    Las Cruces, NM
    Hey, great build thread. Seriously. You got part numbers for the components you used? How much did it cost? How many hours do you have on it now that it's all built?
    Sep 2005
    Pacific Northwest
    That is cool that you got it done. Keep the updates coming.
    Nov 2009
    Quote Originally Posted by rowycoracing View Post
    Not much to update, its been working great for years now. Reverse is great, not bad to shift at all. I try to keep tabs on case level. I did add a neutral spot, much easier.
  1. Camber Change vs Wheel Scrub
    By JD66 in forum Suspension - Wheels & Tires
    Last Post: 05-29-2013, 09:24 AM
  2. Cost to change ratio/quick change
    Last Post: 11-15-2012, 10:02 AM
  3. Planetary Reverse Might be a stupid Idea.
    By opsled in forum Driveline
    Last Post: 02-16-2012, 04:17 PM
  4. Quick Change gears & shafts
    By Shmeefer in forum Driveline
    Last Post: 02-22-2010, 12:10 PM
  5. Quick change rear end gears for jackshaft
    By MXman in forum Driveline
    Last Post: 10-13-2006, 08:55 AM
