Page 3 of 3 FirstFirst 1 2 3
Results 21 to 22 of 22
    Re: FNR gear box issue
    #21
    so for anyone till following this, here is my final conclusion on this matter as it is now fixed. there is no ball and bairing, just a shift fork with a bolt holding it in place by a notch in the arm were the bolt comes through the case. the cog is held in gear by one simple spring on the outside of the case holding the shift fork in the forward position, this spring over time becomes weak and can no longer hold the shift fork in gear under heavy stress or high speed. adding a spring return like a carburetor on a car can not only fix the issue but make it stronger and thus less prone to failure. this took alot of farting around and trial and error to diagnose but seems to have remedied the problem. good luck to anyone that comes across this issue on the chinese made machines, hopefully you read this thread and save yourself some time and money with this remedy.
    #22
    Thats cool. Glad to hear you got it working.
  1. gear ratio of all terrain vehicle
    By alampallysiddharth in forum MiniBuggy.net Lounge!
    Last Post: 02-27-2011, 06:15 AM
  2. cbr gearing??
    By 250r05 in forum Driveline
    Last Post: 05-29-2009, 05:04 PM
  3. Overflow from a project removal...
    By 02RedWS6TA in forum Projects in Progress
    Last Post: 08-09-2006, 01:59 PM
  4. Golf cart axles
    By FLATLINE_curious in forum Projects in Progress
    Last Post: 05-18-2006, 10:45 AM
  5. xqwzit's long travel
    By xqwzit in forum Projects in Progress
    Last Post: 03-09-2006, 08:36 AM
