Results 1 to 9 of 9
    Rear Sprocket Movement?
    I'm pretty new to all this and the terms, but I will try to explain as best as I can. My rear sprocket carrier allows a little sprocket/mounting flange movement. What I mean is that if you grab the rear of the sprocket and push left & right (toward the rear tires), back and forth there is a little movement. And it isn't much. My sprocket is 67 tooth which is almost 14" and when you flex the sprocket it maybe moves 1/8" - 3/16" in/out.
    It's like the splines inside are a little loss fitting or something is loose or is this normal???
    Thanks, any ideas or help most appreciated!!
    Re: Rear Sprocket Movement?
    That's prob too much. Something's is loose/worn out. But depend on size weight and hp it could go a while. Throw up a pic and give some more description.
    Not sure why my signature doesnt show, maybe there is a minimum post count for that now?
    Anyway its a 2010 Quadrocket built rail with a 2007 stock Hayabusa engine, 2 seater, only showing 330 something miles since new.
    Guess I need to see if I can figure out how this carrier assembly comes apart.
    Here is a link where I described the buggy. - - - > https://www.minibuggy.net/forum/show-...busa-rail.html
    Edit: I see my sig works now.
    650 lb. Eagle SST 2 seater sandrail with a 2005 ZX10R, Annitori QS Pro Quickshifter.
    SOLD - 2010 Hayabusa 2 seater - Force Tek kit car.
    "With Age Comes A Cage"
    When I mentiioned the 1/8" - 3/16" above, I meant at the tooth edge of the sprocket, not at the flange. The flange itself isnt moving in and out or side to side. The flange "pivots" slightly if that makes sense and allows the outer sprocket edge to flex the above amount. Sorry I said I didn't know the terms.....
    Sounds to me like you've got a bearing or both bearings out.
    What holds the flanges into each end of the carrier? I had the cv joints disconnected (6 bolts each side) and I didn't see any kind of retainer in there on either side.
    Petoskey, Michigan
    Is it giving you chain issues or sprocket issues?
    Chances are most of us do not know what a Quadrocket rail is so lots of pics will do wonders in getting light on your issue/setup.
    Sprockets were misaligned pretty bad when I got it, but I moved the position of the carrier on the mounting base and got them lined up.
    The big sprocket isn't "flopping around" loose and you have to push on it pretty good to move it, but it will move the amount I mentioned under hard push. And its not the sprocket bending, it is a twist of the flange on the shaft inside the carrier.
    May not be enough to worry about, but I'm a natural worrier.
    I wil try and get a pic of the carrier so yall can see what it has, but I cant very well take a pic of the flex.
    Thanks
    Senior Member Gotted's Avatar
    Apr 2008
    Clarkston WA.
    Is the flange moving on the carrier splined axel that's what I got out of what you wrote.
    The carrier axel mite have the twist or the flange spines could be worn.
    Mine has a c-clips holding the flanges on the carrier splined axel.
    Bearings also could be done that would be a up and down movement can you tell by grabbing the axel and pulling up and down looking at the carrier flange axel bearing seal to see if the movement is there.
    You will have to unbolt a axel from the carrier flange to see whats going on if you cant tell.
    "Imagination is more important than knowledge"
  2. rear Sprocket
    By pauldavies123 in forum Projects in Progress
    Last Post: 06-05-2012, 05:04 AM
  3. The Chain
    By Gotted in forum Driveline
    Last Post: 05-08-2009, 10:40 PM
  4. What size rear sprocket?
    By GoinPostal in forum Driveline
    Last Post: 10-26-2008, 10:57 PM
  5. Questions About Sprockets & Jack-Shafts
    By Kawabuggy in forum Driveline
    Last Post: 12-31-2006, 12:46 AM
