Results 1 to 7 of 7
    Need help with sprocket ratio!
    Jul 2011
    Larnaca, Cyprus
    Hi! I really need help with my sprocket ratios. I have decided to go with the jackshaft method. the sprocket on the motor is 17tooth and on the jack shaft there is a 37 tooth sprocket! what ratio should i run from the jack shaft to my center carrier? 27-28 " tires! and i am not looking for speeds more than 65-70mph.
    also i was thinking of laser cutting the sprockets since importing from the US costs a lot. thanks
    Re: Need help with sprocket ratio!
    2.3:1 on second. Although I'd try to go lower ratio on 1st and high on second to lessen strain on second chain.
    Jul 2011
    Larnaca, Cyprus
    I am totally confused now! what does 2:3:1 exactly means?
    The axle sprocket should be 2.3 times the small sprocket on jack shaft.
    For instance;
    engine 17T jackshaft 37T = ratio of 2.17:1
    then jackshaft 20T rear axle 46T = ratio of 2.3 to 1
    Final ratio 2.17 x 2.3 = 5:1
    Jul 2011
    Larnaca, Cyprus
    Ok! i have the dxf file for a 17 tooth sprocket and a 42 tooth sprocket. which is 2.47 : 1 ratio! very close to 2.3: 1. What do you think about laser cutting a sprocket? will the metal warp?
    You could check local industrial suppliers as the sprockets will be good quality and often the teeth will be hardend, if you lazer cut a template with the same bore and the mounting holes in place you could produce your own finished sprockets.
    http://ablproducts.com/50-chain-sprocket.html
    http://www.fremontindustrialsupply.com/servlet/the-ALL/keyword/50-flat-sprocket/s/9/Categories
    Thanks Ironknot
    Jan 2009
    Clarkston, MI
    Gvouvakos,
    I just had a 64 tooth sprocket laser cut for me. It is for a 530 chain, out of 5/16 hot roll, mild steel.
    It works fine and runs smooth. The cutter charged me $50 including material. I suspect if I had several cut at a time, I could get the price for each to less than $30.
    Time will tell how well it holds up, and if the chain will show any wear. But so far, it looks ok.
    Leo
  1. Sprocket ratio for 13hp
    By Bitpharked in forum Driveline
    Last Post: 03-20-2013, 08:52 AM
  2. DXF's of revrse sprocket & 60T 530 sprocket
    By grga88 in forum The Drawing Room
    Last Post: 09-02-2012, 07:24 AM
  3. Ratio ?
    By powermizer in forum Driveline
    Last Post: 04-28-2011, 10:53 AM
  4. The Chain
    By Gotted in forum Driveline
    Last Post: 05-08-2009, 10:40 PM
  5. Golf cart axles
    By FLATLINE_curious in forum Projects in Progress
    Last Post: 05-18-2006, 10:45 AM
