Results 1 to 4 of 4
    Transaxle for UTV build
    I'm thinking about building a UTV type vehicle to use around our farm using a 20hp Kohler engine and this Dana Spicer transaxle with FNR:
    Surplus Center - UTILITY VEHICLE TRANSAXLE W/AUX 4WD SHAFT
    http://www.surpluscenter.com/pages/Catalog285-120.pdf
    I saw on the specs that it has a auxilary output shaft that can use a right angle gearbox to run to a secondary differencial to use in a 4x4 application, which I would like to do. Does anyone see any issues with doing something like this?
    Thanks,
    Ed
    Re: Transaxle for UTV build
    S.W. Michigan
    only 48" wide,,,but looks like it could work nice on a small 20hp vehicle.
    good price for FNR & axle
    Its geared deep, but setup right with a cvt it would be sweet. Offset wheels would put you out to 60" easy. +1 on a good price.
    Hope you don't plan on going very fast. Its geared very, very deep, 13.25:1 foward, 14.36:1 reverse. So with a 26" tire @3600 RPM you only get a top speed of 21 MPH!
    I have 2 of them (1 for spare) powered by a 10HP Diesel and a Comet 40 CVT with a chain reduction. Haven't got it on wheels yet but the drivetrain is done.
    Also don't plan on making it 4WD very easily. The 4WD output shaft is reverse rotation with a 4.89:1 reduction from the input shaft. The only UTV that I have found that uses this transaxle is the China one from Tractor Supply and it uses the 2WD version, not the 4.
    By leok in forum Barracuda
  3. Kids Kart Build
    By Nobody077 in forum Frame
