Thread: Homemade FNR
Results 1 to 4 of 4
    Homemade FNR
    Got a gearbox with the diff was looking at it today and came up with the idea to make an FNR
    The diff drive gear is a 4 to 1 reduction gear if I strip out every thing other than 4th gear (1 to 1 ratio) and reverse modifiy the housing to make it alot smaller and there ya go
    4:1 reduction FNR box with a diff
    Was wondering if this has been done before and does anyone have any links to this on the net
    Cheers Reece
    Re: Homemade FNR
    Oct 2009
    Thats great but what diff are ya using ? And a couple of picts might help explain better
    Re: Homemade FNR
    Re: Homemade FNR
    Right details for those interested box and diff are from a toyota corrola front wheel drive, toyota mate them up to the 4age motor so 135hp standard and alot of boyracers push them into the 200hp range so should be good for running a busa
    Thanks for the link bull, funny its another kiwi that has done it
    here is the diff
    here are the main shafts
    My daft idea was to take 4th gear, grind the shafts so I can move 4th gear to where 3rd is leave reverse in place mount a bearing on the shafts where 4th gear was
    Modify the shifter rings to work as a pair that way one shift is forward or reverse
    I'd use bulk of the housing as is, diff section plus the bellhousing end wall just trim the bell off, the other end I'd fab up something and machine some bearing mounts
    A fair bit of work but I should end up with a cheap unit that is small-ish and good enough to do the job and the CV's are nice en long and as common as muck
    Oh and I'd set it up for a chain drive, this leaves a weak link that is easy to replace
    So what ya think daft enough it might work?
    Cheers Reece
  1. Homemade Gearbox /Diff (Photos)?
    By Jetboy_05 in forum Driveline
    Last Post: 11-13-2011, 06:48 PM
  2. Homemade hids or headlights?
    By Bullnerd in forum Controls and electrical
    Last Post: 04-10-2011, 11:29 AM
  3. Homemade pipe bender
    By daaboots in forum Projects in Progress
    Last Post: 02-21-2010, 07:20 AM
  4. Homemade transaxle?Kind of?
    By Bullnerd in forum Driveline
    Last Post: 10-21-2009, 05:51 AM
  5. Homemade belt notcher(well.. idea anyway)
    Last Post: 12-07-2008, 08:15 AM
