Results 31 to 39 of 39
    Re: Micro Stub Fundamentals
    #31
    Senior Member JD66's Avatar
    Jan 2013
    San Diego, CA
    Looking like the way to go is Intrepid hub and F150cv/stub, keep as many off the shelf parts as possible. I plan to run inboard brakes, but would like to leave the option open for outboard. I'm thinking about a 5 link setup, need to read through Slow Build by Engineer's build thread. I like the packaging for my spare tire (will be above the motor) better with the shocks forward of the rear wheels so thinking either 3 link or 5 link.
    #32
    Yes i'm running a fixed 930 inner cv. Inboard brakes. But with the intrepid hub drill for chevy pretty sure you can run the hat/rotor that comes with the empi racetrim setup?3
    VW Brakes – Dune Buggy Braking Systems | AppleTreeAuto.com
    #33
    Jan 2013
    San Diego, CA
    Ok, cool. I already have parts to run inboard brakes, so no need for brakes at the wheel hubs but nice for future changes if needed.
    #34
    I'm assuming you have to run a spacer of some sort if not running outboard disc's?
    Is there someone that makes this spacer?
    When eliminating the brake rotor, there is a gap between the VW wide 5 adapter and the bearing assembly. I purchased all of my rear drive parts and forgot to take this into consideration. With the stub axle in the bearing assembly, there is no way to mount the wide 5 adapter without a solid surface to make up for the missing rotor.
    The cap on the wide five adapter hits the end of the micro stub by alot, it almost looks as though even with a brake rotor on the small 5 pattern the center would not go.
    Is there a spacer I'm missing between the micro stub and the bearing?
    #35
    Senior Member NoClue's Avatar
    Aug 2008
    Fullerton, CA
    It's the rotor hat the makes up the difference. I ended up having the adapters machined out to fit.
    #36
    Quote Originally Posted by NoClue View Post
    So you just did away with the small cap that covers the nut (36mm) on the adapter?
    The nuts that come with the adapter would have to be changed for shorter, as they have a shoulder on them right?
    #37
    Aug 2008
    Fullerton, CA
    Ahh. I don't have one...yet. The adapters I have are from the empi/race trim kit. Planning on on eventually buying the caps, but they cover the lug nuts of the hub.
    Check starting from post 92 on my build thread.
    https://www.minibuggy.net/forum/proje...em-lol-10.html
    #38
    Sometimes.........doh!
    Problem solved, much less expensive than having a machine shop CNC from stock.
    12mm 5x4 75 5x120 7mm 70 5 Chevy GMC Pontiac Olds 5LUG Flat Wheel Spacers | eBay
    #39
    FYI I've toasted 3 Timken intrepid bearings (replaced under warrenty LOL) beacause the f150 splines are bottoming out before the cv cup pulls tight against the bearing. I'm running the 3/8 spacers but I used on the nut side. I had designed my non plunge setup with f150 cv right where it is and puting spacer on outside moved the cv 1/4" Thats too much for a non plunge setup.
    So I found some BIG washers at McMaster-Carr that are 1/8" thick and now it snugs up nicely.
  1. Short Spline / Micro Stub
    Last Post: 11-19-2012, 04:09 PM
  2. Need micro stub: ATV stub to 930 CV
    By Wayneski in forum Suspension - Wheels & Tires
    Last Post: 09-19-2010, 09:58 PM
  3. Micro stub recomendations anyone?
    By intfit in forum Driveline
    Last Post: 07-17-2010, 02:07 AM
  4. Micro stub mounting
    By robracing in forum Driveline
    Last Post: 03-25-2010, 11:53 AM
  5. Micro Stub dimensions, again
    By hero_saku39 in forum Driveline
    Last Post: 07-14-2008, 08:09 PM
